Help With Particle Photon Temperature
So I have the hard part, or so I think, out of the way with a project I’ve been working on. It uses a particle photon that is battery powered and goes under my pool skimmer basket. I have two sensors attached to it one is a ds18b20 temperature sensor and the other is a sonic distance sensor. It wakes up every 4 hours and takes a temperature and a distance reading publishes them to the particle cloud and then goes to sleep. The distance Im using to determine if i need to turn on the water to top off the pool or if the level is okay. The temperature I want to ultimately get into smartthings so that it can display on action tiles or also be used in automations to turn on other smartthings connected devices. It isn’t 100 percent necessary to get the distance meaurement into smartthings but both would be cool too. What is the easiest way in my scenario with the board only being awake for a short few seconds each day to get this data into smartthings so it can start being useful to me? Has anyone written a device handler for this type of device?
