Outdoor Light Switch options?
Is anyone aware of a light switch (Zigbee or Z-Wave Plus, or I guess WiFi) that is rated for outdoor use? I have a pool filter thats on a standard single pole on/off light switch that I would like to convert to a SmartSwitch. Its inside a standard light switch covered enclosure with a lid on it.
I couldn’t find anything outside of the outdoor plugs, but I need a switch unfortunately.
There are a couple of options.
You didn’t say what country you’re in, and that does make a difference, so I’m going to assume that it’s the US, but if it isn’t, speak up. :sunglasses:
Anyway, I think one of the most popular options for a light switch is to just use one of the in wall Micros. This can be placed anywhere along the circuit branch. And then it can be used with the existing switch in most cases. So that’s often the simplest solution.
However, before we go any further it’s really important to ask about the specifications of the particular switch you want to make smart. Your topic title said “outdoor light switch,“ but your post said “pool filter,“ and those are usually very different specifications. Since this is for a pool filter, those are often not your standard 120 V 15 amp switches. If this is for either a 220 V line or a 30 or 40 amp switch, that’s going to make a huge difference.
There are several outdoor rated options that work for water heaters or pool equipment or other higher amp equipment. Some are added in line so again you continue to use the existing switch, and some are replacement switches. See the following discussion thread:
Switch for hot water heater?
So anyway, there’s probably a good solution, but we do need to know a few more details. :sunglasses:. The brand and model number of the pool filter would help, too.
Thanks for the insight. Yes, US. It is a C55cxklt-5007 in 115v operation (so i guess 120v?) with a max amp of 8.5 according to the sticker on it.
I think I’ll look into a relay and maybe just splice it in somewhere in the basement.
thanks again!
Specs sound good. And agreed, an inline relay sounds like the simplest option. :sunglasses:
