I have a weird situation where I have 3 smart bulbs hooked up with a lightify dimmer. On power down, 2 of the bulbs just shut off and one dims. I checked and the firmwares are all the same, I’m at a loss as to why this is happening or how to fix it.
It sounds like you are saying you are turning the 3 bulbs on and off with the dimmer. You should not do that. Smart bulbs should always be left on power so their radio will be powered to hear commands. If you would rather use a smart dimmer on all 3 lights at once then change the bulbs to dumb rather that smart.
i’m actually using a wireless lightify dimmer. the physical switch is always in the on position. the problem I am having in the 2 bulbs aren’t dimming when told to turn off, one is.
I see, thanks for the clarification. I’m afraid I don’t have any experience with the lightify products so I’m not sure what may be causing this behavior.
yesterday I reset the bulb that was dimming (turning it on and off 3 seconds x 5) now all 3 bulbs just shut off and dim. it’s sort of a fix, but i dont understand why every other light in the house that’s A19 tunable will dim but these bathroom lights won’t. It’s odd
i don’t know if there’s a custom DTH for these bulbs or not, i’ve looked but with no luck
