I have some OSRAM 73703 Lightify Led Rgbw A19 bulbs and while they do work but when power cycled they lose what ever color or dimming setting you set on the app.
These are on a conventional light switch is this a problem?
The smartthings support suggested I try some questions here first. I have tried this setup with 2 of the OSRAM selections available and also as a Hue Zigby LED bulb.
I do not have any kind of bridge just the Smartthings Hub, and I would prefer to keep it this way if possible.
Yes, it’s expected behavior. Where I use smartbulbs of any brand as overhead lights I’ve hard wired them and only use automation or soft switches to trigger. Probably not up to code because I believe you are required to have a switch but it works well for me.
Do you only ever want them to be a certain specific color or are you wanting them to be one of maybe 3 or 4 different colors depending on mood, weather, etc?
If it’s 1 color only, you could tie these bulbs to virtual switches and use Rule Machine.
Set up a rule like this: trigger Bulb 1 switches on, condition Virtual Switch is on, set color of these bulbs
The light will come on white, but quickly change to the other color.
If you are wanting multiple colors, you could still do this, you would just need to add additional rules to determine which virtual switch is on and which color it sets the bulb.
FYI, I use Rule Machine to set the color of the RGBW strips when certain events are triggered. Also, I use it for setting a color. It turns any other color off when a different color is selected.
