One device disappeared from Google Home
My home’s been humming along just fine for a while. My Google integration isn’t perfect, but it works. Just in the past couple days (I have not changed anything) I’ve had ONE device, my garage door opener (GD00Z-4) is gone from Google Home. It’s still in SmartThings and works just fine, but it is not in Google Home. Every other device is and works fine. Not sure how to fix this - thoughts?
Hey there!
Thank you for reaching out for assistance with your concerns.
As it appears in your ST application, I would recommend re-linking your Smartthings Account to your Google Home. Have you also tried to perform a device sync? “Ok Google, Sync Devices” If your using Android, Clearing the cache and restarting the Google Home Application may help you.
After perfroming the above steps, I would check to ensure that the Garage Door is back showing as a device linked to Smartthings or As a device needing to be added back to a room. You can confirm this by Locating your Home Control Settings in your Google Home Application and checking to see if the device is now showing.
If you continue to have issues after trying the above steps, I would recommend reaching out to Google directly for further assistance.
I hope this message finds you well!
^SamsungZell
My led lights disappeared from Google and I already tried all the suggestions of the op and my device is still missing from Google home.
