I got a blue light on my hub. I tried hard resetting. Still blue light. I tried swapping the cable. No improvement. Is there anything else I can do to try to repair this? I am trying everything I can to avoid replacing this as I have so many different devices on it, it would be a pain to start over.
I got a green for only have a minute when I pulled the plug and battery. Then went back to blue. Weird. It’s completely connected to a working router.
Did you try changing the port it is connected to on the router?
Was it working before? Did something change?
Check port forwarding, it means its having issues connecting to ST cloud.
Yes, somehow changing the port worked! Why would that affect anything??? Anyway, relieved.
If you recently changed the port in the router it could.
Router/switches keeps a table with addresses and what port they are on. They usually auto update, but can sometimes cause issue. Rebooting the switch would do it too.
Mine went down today as well, solid blue light. Had to hard reset the hub, pull batteries and power, twice to get it to come back up.
