I’ve been seeing scheduling issues as well on the platform, but so far the watchdog’s that I’ve implemented on my Ecobee driver have successfully recovered automatically every time for the last several days.
According to my logs my last disconnect was: when=2016-02-05 22:15:50 CST. But that was actually due to some of the scenario testing I was doing on my code, so would have been up even longer.
I’ve had issues every day this week and sometimes multiple times a day. I’m just going to go back to using IFTTT for now based on the presence of a single user.
I also have had solid connectivity with @StrykerSKS’s code for several days now. I only had to re-enter credentials once 2 days ago and that seemed to coincide with ecobee pushing down the latest FW (553) to my ecobee3.
I was directed to a smartapp that creates a ‘combined presence sensor’. This lets you use IFTTT to control home and away modes. Worked like a charm for me! I suggest you take a look at this:
But right now I’m using @StrykerSKS’s code with Rule Machine to control my home and away modes as I also want to control ‘sleep’ which IFTTT can’t do.
@Snakedog116
Thanks! I figured there must be something like this already. I had done something similar with a virtual switch and rule machine, but this is a bit cleaner.
You are correct according to the ecobee Support Knowledgebase
What is the difference between ecobee3 and HomeKit-enabled ecobee3?
ecobee Support
posted this on December 8, 2015, 9:27 PM
The only difference between the two products is that our HomeKit-enabled ecobee3 supports Apple HomeKit technology. All other features are the exactly the same.
The product roadmap from a firmware and software perspective (not including HomeKit) remains the same for both ecobee3 and HomeKit-enabled ecobee3.
@snaggletoothrex SmartThings has already started pushing updates to the Github repository with updates on the device type. So they are definitely making progress. I know some users are using the DTH that is in the repository rather than waiting for it to be published to the marketplace.
[quote=“johnosstyn, post:29, topic:37341”][quote=“Tyler, post:22, topic:37341, full:true”]
Hi all!
A quick update on our official Ecobee3 integration. We’ve completed the integration and we’re beginning testing this week. We expect that testing to take about two weeks.
The main fix/improvement in our official integration is related to an issue with previous integrations that would cause Ecobee to log you out. We’re also updating the UI, adding fan support, celcius support and correcting a few other issues you all had reported to us.
Stay tuned![/quote]
Did this ever happen?
[/quote]
