[OBSOLETE] - Universal ZigBee Lock DTH with Lock Codes
Thanks @jhamstead - great turnaround!
Folks using any of the following SmartApps should update to the latest 1.3a handler:
Any chance the set code feature will be able to work on Yale Zigbee locks in the future?
I’m not sure what you mean. setCode is fully supported on all ZigBee locks with my DTH including Yale.
If you have a Yale version that is not working let me know the model and fingerprint.
Hello
In the release notes of the handler it says:
Setting/Deleting/Updating Lock User Codes as well as reporting their use to lock manager SmartApps. Enhanced lock action status: jammed lock, used code information, manual/remote notification.
Yale Locks Only: Volume, AutoLock, Privacy Mode, Wrong Code Entry Limit, Invalid Code Entry Lockout Time, and One Touch Locking are all configurable.
On my Yale YRD210 I cant seem to be able to manage any access codes from the app
Am I doing something wrong? Apologies I am new to the smartthings world
The code management must be done through a SmartApp. My code is a DTH that allows for the SmartApps to work with ZigBee locks. There are two main SmartApps available in the community.
The first is a free version by @ethayer’s. I personally use this version.
The second is by @RBoy. It is a paid version but highly regarded.
I loaded Ethayers Lock Manager yesterday, did all the config through Github loaded the 3 child apps, and then configured the Universal Zigbee handler and edited it in My devices.
I loaded the Lock Manager and can configure new access codes but they dont seem to upload to the lock? am i missing something?
If everything is working, you should see a message like below in the recently tab.
If you are not seeing this message, check again to make sure everything is installed correctly. If that still doesn’t work, it would help to see your live logs for the SmartApp and lock when adding a new code. If you send live logs, I’d recommend sending them in a PM to me.
Holy F&#@, after I went to that view in my smart app everything started working, I removed the lock and app and started over…oh well cant thank you enough, it seems to be working Hooray!
Have a nice weekend!
Spencer
Update: Version 1.4 Released. This version modifies Health Check to match SmartThings changes to the default ZigBee Lock DTH. To enable the new settings, press force reconfigure button after upgrading.
I have a Yale Zigbee lock. Will this app let’s you change the time of the Autolock to a custom time? 30 seconds is too short. If not, is there an app that will do that for the Yale zigbee? I don’t need the other features.
Yes. This DTH will allow you to change the Autolock time for Yale locks up to 180 seconds. You can adjust the preferred time in settings, then enable Autolock if not enabled.
Is there a way to make it longer? I was thinking of 10 minutes.
You can use the Enhanced Auto Lock Door SmartApp form the Marketplace. With this smartapp you can even define a contact sensor to check if the door is closed/open before trigger the lock/unlock command.
Att,
Marcos
Enhanced auto door lock seem to require door sensors, which i don’t have.
I just want something that when a door is unlocked, wait a specified time (ie 10 minutes) and then check status of the lock. If it is still unlocked, then lock it. If it is already locked then don’t do anything.
I don’t want it to issue a lock command when it’s already locked, that seems like a waste of battery for the lock everyday.
The device is still in contact with the hub, a couple lock commands that won’t do anything isn’t going to affect your battery appreciably.
So it’s not going to try to force the motor to turn if it’s already locked?
Well, again, I can’t seem to get Enhanced door lock to work without setting a door sensor, which I don’t have.
I also try changing the code of this device handler, changing the range from 180 sec to 1800 sec. When i put in a value larger than 180, I am not able to enable AutoLock feature.
Just tested it out. As I thought, using Autolock, it tries to engage the motor to lock the door, even when it is already locked.
That can’t be good for the motor can it?
I would rather do a smartapp autolock that sees whether it is locked or not.
Am i able to use any of the smartapps for the Z wave version on a Yale Zigbee lock?
Mine don’t do that. The lock knows it’s locked so doesn’t try to relock. Not sure what to tell ya on that one.
