Lock Manager
Incomplete List of features:
- Manage user codes on locks.
- Manage Keypads.
- Review and manage active lock codes.
- Set lock access based on schedules.
- Receive notifications when a user used their code.
- Run Hello Home phrases based on lock/unlock events.
- Manage Hello Home phrases based on keypad inputs.
This app works using 3 child apps and 1 parent app. It is recommended that you install all 4 apps, however if you do not use keypad devices, it is not required to install the keypad child app.
Note: If upgrading from any beta version, it is required to uninstall the app completely before installing. The architecture of this app has changed in
a way that is incompatible with previous versions.
How To Install
User guide has old information. There is now only one app to install, and no child apps. Leaving the link here, because there is still reliant information, but this guide is for version 1.0 and not version 2.
App no longer requires special Device Type Handlers. There are two special device handlers in the repo simply to supply options to turn special features on/off in settings.
Version 2.0
Version 2.0 does not learn codes and will roll over any existing codes it can. This is to prevent errors like⦠existing code 1234 is on slot 2 but you choose slot1 and thereās a conflict. Lock Manager should be your single point of truth for codes, and it behaves this way. If LockManager detects a code that is not part of the app, it will attempt to delete it.
Please donate
Donations are completely optional, but if this made your life easier, please consider.
Google Wallet- Send to: thayer.er@gmail.com
