[OBSOLETE] Hue B Smart (Groups & Scenes) - Remove Popcorn Effect!
HUE B SMART
Hue B Smart - total control of Hue Bulbs, Groups, Scenes, and more!
This is a Updated and Working verison of the Hue B Smart App created by @infofiend
Orignal App is here [OBSOLETE] Hue B Smart (Smart and FAST Hue Lighting)
The working code is available here
  • The fix to add new bridges and/or fresh install the app
  • Bug Fixed - Lights reverting to 1% brightness when turned off with transitiontime
  • Transition Time setting moved to DH preferences
  • Follow SmartThings Colour codes
    The following is on all DH’s as infofriend only did half
  • Moved scaleLevel from HBS service manager to DTH (less network traffic)
  • Removed many log entries (log now significantly less chatty)
Updated Version 1.2 9th November 2017
  • Fixed Update problem due to bulb,scene or group deleted from hue without removing it from smartthings first. Thanks to @Collisionc
  • Added FlashCoRe for webcore usage. Requested by @Mark_Rorem
Updated Version 1.3 13th November 2017
  • Added White Ambiance group DH
Updated Version 1.4 7th December 2017
  • Fixed IDE Logging Information + Other Bug Fixes
Updated Version 1.5 & 1.6 28th January 2018
  • Removed Non-Working Quick Fixes from App & DH’s
  • Removed Non-Working Schedules from App & DH’s
  • Added Light Capability to all Light DH’s
  • You can now turn off debugging for the SmartApp
  • The IDE Logs have been made more pretty for when they are on (Now uses trace, info, warn and error)
Updated Version 1.7 9th September 2018
  • Made changes to work with ST Backend update on the 6th September
Just wanted to say why I forked the original code not just to fix it but I didn’t like the DH for the lights here is what they look like
Any features requests or bugs found just let me know
White Ambiance
Lux Bulb
Lux Group
Colour Bulb
Colour Group
Scene
Moved transition time to the settings menu
NOTE: It is not required, nor necessary to donate to use this SmartApp. This is a free open source software, That I have taken over development as no one else did. But if you feel like it, you can donate here.
Thanks very much @Michael_D for the advice. Got my hub and most of my bulbs set up without trouble! Still not able to add my regular Hue white (not white ambiance). All the issues I previously had was down to user error mixed with not understanding just how ST works! Thanks to @tmleafs and @infofiend for creating such a comprehensive app. Samsung should really ship ST with the ability to work with popular platforms like Hue better.
This is great. What an improvement over Philips implementation. I was able to drop a few virtual switches now that I have my Hue groups listed without having the individual bulbs. Not to mention having push button scenes… The wife acceptance factor is going up today.
Thanks for starting a new one.
tmleafs,
Any chance to look at my request above to rename flash to flash_on or something similar I posted in the previous posting?
This is so I could use the flash command in the DTH since WebCoRE also has an emulated flash command. I was able to fix it on my own and confirmed it works if it’s renamed in the DTH with WebCoRE.
Does this app support quick updates to the state of the Hue bulbs.
The default super LAN Hue in ST takes around 10 minutes to show the correct color temperature and state.
I installed the app and DTHs but it is still stuck on “searching for hue bridge” for more than an hour. I have tried pressing the pair button the bridge as well but no dice.
You need to remove all standard hue apps and devices before you can install this one.
On this app it’s a refresh every 5 minutes which is what I believe the official app used. You can only pull information from the hue bridge it can’t be pushed which is why we have the lag. Best option is to use smartthings devices to control lights and not use the hue app or hue sensors or buttons
Oh ok. Thanks!
Something really odd happened to me yesterday all of my bulbs were working fine when being triggered by motion until about 8PM central time, and then suddenly my motion events were turning my bulbs off not on. In the IDE logs and recent event logs, I could see that the command to turn the bulb on was being sent, but the reverse was happening.
I removed all of the bulbs from smartThings as well as the app and then recreated all of my automation again after adding the app back in.
I am not sure if this was a Hue B smart issue or a smartThings issue, but it was very odd. Has anyone else experienced this?
My Hue B Smart has stopped being able to get updates from Hue again.
On doing a device search I get the following in the IDE
43aec1b5-02fa-4728-a3a1-5b683138f88b 03:51:31: debug Manage Bridge 192.168.2.31
43aec1b5-02fa-4728-a3a1-5b683138f88b 03:51:28: debug unknown response: [sensors:[2:[uniqueid:00:00:00:00:00:40:76:a0-f2, name:Living Room Tap, state:[buttonevent:34, lastupdated:2017-09-18T02:38:37], modelid:ZGPSWITCH, config:[on:true], manufacturername:Philips, type:ZGPSwitch, swupdate:[lastinstall:null, state:notupdatable]], 10:[uniqueid:WA0001, recycle:true, name:Dimmer Switch 8 SceneCycle, state:[status:0, lastupdated:none], modelid:PHWA01, config:[reachable:true, on:true], manufacturername:cQr0ypBdCqH5ev09MA5BCBm8nTNx0G7n, swversion:1.0, type:CLIPGenericStatus], 1:[name:Daylight, state:[lastupdated:2017-09-18T02:38:23, daylight:false], modelid:PHDL00, config:[configured:true, on:true, sunsetoffset:15, sunriseoffset:30], manufacturername:Philips, swversion:1.0, type:Daylight], 9:[uniqueid:PFHS-LIGHT-STATE, recycle:false, name:Light status, state:[status:0, lastupdated:none], modelid:Model 2015, config:[reachable:true, battery:null, on:true], manufacturername:all 4 hue, swversion:1.0, type:CLIPGenericStatus], 8:[uniqueid:00:17:88:01:10:3e:2b:30-02-fc00, name:Bedroom Dimmer, state:[buttonevent:null, lastupdated:none], modelid:RWL021, config:[reachable:true, pending:[], battery:76, on:true], manufacturername:Philips, swversion:5.45.1.16265, type:ZLLSwitch, swupdate:[lastinstall:null, state:noupdates]], 11:[uniqueid:L_01_oEppe, recycle:false, name:HomeAway, state:[presence:false, lastupdated:none], modelid:HOMEAWAY, config:[reachable:true, on:true], manufacturername:VmcH3c3mCREfZpsE2qbJBXMFkR8Wo01u, swversion:A_1, type:CLIPPresence]], lights:[21:[uniqueid:00:17:88:01:02:ca:87:40-0b, productid:Philips-LCT010-1-A19ECLv4, name:Nursery, state:[bri:252, effect:none, sat:248, reachable:true, alert:none, hue:13881, colormode:xy, on:false, ct:286, xy:[0.4081, 0.5173]], swconfigid:F921C859, modelid:LCT010, manufacturername:Philips, swversion:1.15.2_r19181, type:Extended color light, swupdate:[lastinstall:null, state:noupdates]], 20:[uniqueid:00:17:88:01:00:ee:04:a9-0b, name:Second Bedroom, state:[bri:1, reachable:true, alert:none, on:false], modelid:LWB004, manufacturername…[TRUNCATED]
Hoping I can get some help as I’m having trouble connecting my hub. I’ve read through both threads on this, have the latest code from https://github.com/tmleafs/Hue_B_Smart. I’ve removed all existing hue devices in ST. I’ve tried reinstalling Hue B Smart several times as well.
The ST mobile app screen sits on searching for hue bridges. I don’t see any errors in the logs and see this.
[redacted] 10:10:38 PM: debug Discovery Response is [devicetype:04, mac:[redacted], networkAddress:[redacted], deviceAddress:[redacted], stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:[redacted], ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:[redacted]].
[redacted] 10:10:38 PM: debug Previously found bridge discovered
[redacted] 10:10:38 PM: debug Discovered bridge [redacted] (X.X.X.X)
[redacted] 10:10:37 PM: debug Found new bridge.
[redacted] 10:10:37 PM: debug Discovered bridge [redacted] (X.X.X.X)
[redacted] 10:10:37 PM: debug Discovery Response is [devicetype:04, mac:[redacted], networkAddress:[redacted], deviceAddress:[redacted], stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:[redacted], ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:[redacted]].
[redacted] 10:10:37 PM: debug Sending bridge discovery.
[redacted] 10:10:37 PM: debug Doing Hue Device Sync! inItems = null
[redacted] 10:10:37 PM: debug Initialize
[redacted] 10:10:37 PM: debug Updated with settings: [:]
The bridge discovery repeats many times and there are a few lines of this:
Sending verify request for [redacted] (X.X.X.X:80)
I’ve removed the unique identifiers from the logs, but the IP address matches the LAN address and the mac address of my hue hub.
Trying to install this too - spent an hour reading the old thread, i’ve got the point where it’s searching for devices and doesn’t find anything. Have tried adding and deleting a few times with no luck. Log seems to display a loop. Here it is.
    2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:40: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:40: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:40: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:40: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:41: debug *********** dfDvKEuxWdhgdymappWsbhhHzDG6ytHHCr0-vSaR ********
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:41: debug *********** 192.168.0.26:80 ********
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:41: debug Initialize Bridge [ip:192.168.0.26, username:dfDvKEuxWdhgdymappWsbhhHzDG6ytHHCr0-vSaR, deviceId:00178822EFE6]
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:40: trace Bridge discovering all items on Hue hub.
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:38: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:38: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:38: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:38: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:35: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:35: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:35: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:35: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:33: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:33: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:33: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:33: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:31: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:31: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:31: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:31: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:28: error java.lang.ArrayIndexOutOfBoundsException
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:28: trace parse()
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:28: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:28: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:28: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:28: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:26: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:26: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:26: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:26: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:26: debug *********** dfDvKEuxWdhgdymappWsbhhHzDG6ytHHCr0-vSaR ********
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:26: debug *********** 192.168.0.26:80 ********
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:26: debug Initialize Bridge [ip:192.168.0.26, username:dfDvKEuxWdhgdymappWsbhhHzDG6ytHHCr0-vSaR, deviceId:00178822EFE6]
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:26: trace Bridge discovering all items on Hue hub.
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:23: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:23: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:23: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:23: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:21: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:21: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:21: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:21: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:19: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:19: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:19: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:19: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:16: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:16: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:16: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:16: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:14: error java.lang.ArrayIndexOutOfBoundsException
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:14: trace parse()
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:14: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:14: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:14: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:14: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:11: debug Manage Bridge GET Hue B Smart Bridge (192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:11: debug Manage Bridge Params 00178822EFE6
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:11: debug Manage Bridge 192.168.0.26
2cfc01aa-418e-49ee-863b-8922d889f55a  15:47:11: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-00178822efe6={schedules={}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-00178822efe6, itemsDiscovered=false, networkAddress=C0A8001A, ssdpNTS=null, serialNumber=00178822efe6, bulbs={}, mac=00178822EFE6, deviceAddress=0050, hub=e4c964f4-03ab-4ae8-946c-735263105919, ssdpPath=/description.xml, ssdpTerm=urn:schemas-upnp-org:device:basic:1, stringCount=04, scenes={}, verified=true, name=Philips hue (192.168.0.26), devicetype=04, groups={}}
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:11: debug *********** dfDvKEuxWdhgdymappWsbhhHzDG6ytHHCr0-vSaR ********
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:11: debug *********** 192.168.0.26:80 ********
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:11: debug Initialize Bridge [ip:192.168.0.26, username:dfDvKEuxWdhgdymappWsbhhHzDG6ytHHCr0-vSaR, deviceId:00178822EFE6]
ca466704-83f5-4cb9-bf3c-ae74200bf99e  15:47:11: trace Bridge discovering all items on Hue hub.
 15:47:09: info Waiting on events...
 15:47:09: info For past logs for individual things go to the My Devices section, find the device and click on the Events link on the device information page.
 15:47:09: info This console provides live logging of your SmartThings.
So the bridge gets linked?
Just devices isn’t good enough the original connect app needs to be removed too
Have you added new devices? If so what devices were they?
No new devices added to Hue. As far as I’m aware the setup hasn’t changed.
I need to seen more log before and after what you have already posted and use the “Preformatted text” button to make it easier to and pretty like @realdannys did
I’ll see if I can grab that.
I’m wondering if there’s more in the JSON string but is there anyway of
getting the log without it being truncated?
afraid not limitation of smartthings
Here you go. Will try to get the full response from the Hub next week (currently out of the country)
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:22: debug Manage Bridge GET Hue Bridge
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:22: debug Manage Bridge Params 28C68EFE1D5F
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:22: debug Manage Bridge 192.168.2.31
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:22: debug Manage Bridge uuid:2f402f80-da50-11e1-9b23-0017882a7e06={schedules={3={id=3, groupId=10, status=disabled, sceneId=null, name=Dimmer Switch 8 Reset, type=schedule}, 7={id=7, groupId=0, status=disabled, sceneId=rSXM8OzTdj97NAu, name=L_04_dHU3H, type=schedule}, 6={id=6, groupId=12, status=disabled, sceneId=null, name=Wake up 1, type=schedule}}, ssdpUSN=uuid:2f402f80-da50-11e1-9b23-0017882a7e06, itemsDiscovered=false, networkAddress=C0A8021F, ssdpNTS=null, serialNumber=0017882a7e06, bulbs={21={id=21, state={bri=1, effect=none, sat=252, hue=54953, alert=select, reachable=false, on=true, colormode=xy, ct=250, xy=[0.3824, 0.1603]}, label=Nursery, type=Extended color light}, 2={id=2, state={bri=1, alert=none, reachable=true, on=false}, label=Landing, type=Dimmable light}, 20={id=20, state={bri=1, alert=none, reachable=true, on=false}, label=Second Bedroom, type=Dimmable light}, 1={id=1, state={bri=254, effect=none, sat=222, hue=29274, alert=select, reachable=true, on=false, colormode=xy, ct=234, xy=[0.3692, 0.4288]}, label=Living Room Lamp, type=Extended color light}, 10={id=10, state={bri=25, alert=none, reachable=true, on=false, colormode=ct, ct=225}, label=Dining Room 1, type=Color temperature light}, 6={id=6, state={bri=254, effect=none, sat=201, hue=7648, alert=select, reachable=true, on=false, colormode=xy, ct=447, xy=[0.5033, 0.4152]}, label=Hue Go, type=Extended color light}, 5={id=5, state={bri=8, effect=none, sat=94, hue=41520, alert=select, reachable=true, on=false, colormode=xy, xy=[0.3286, 0.3227]}, label=Bias Lights, type=Color light}, 19={id=19, state={bri=102, alert=none, reachable=false, on=true}, label=Porch, type=Dimmable light}, 9={id=9, state={bri=1, alert=none, reachable=true, on=false, colormode=ct, ct=343}, label=Bedroom, type=Color temperature light}, 8={id=8, state={bri=28, alert=none, reachable=true, on=false, colormode=ct, ct=225}, label=Dining Room Lamp, type=Color temperature light}, 13={id=13, state={bri=25, alert=none, reachable=true, on=false, colormode=ct, ct=225}, label=Dining Room 4, t...[TRUNCATED]
fb104897-45ac-432a-abdc-5aca7e9e28d4  17:37:22: debug *********** dtnkV8i-YleEnZhiplRuw4qNWy07nWj9nhXTXuwG ********
fb104897-45ac-432a-abdc-5aca7e9e28d4  17:37:22: debug *********** 192.168.2.31:80 ********
fb104897-45ac-432a-abdc-5aca7e9e28d4  17:37:22: debug Initialize Bridge [ip:192.168.2.31, username:dtnkV8i-YleEnZhiplRuw4qNWy07nWj9nhXTXuwG, deviceId:28C68EFE1D5F]
fb104897-45ac-432a-abdc-5aca7e9e28d4  17:37:22: trace Bridge discovering all items on Hue hub.
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:21: debug Previously found bridge discovered
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:21: debug Discovered bridge 0017882A7E06 (192.168.2.31)
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:21: debug Discovery Response is [devicetype:04, mac:0017882A7E06, networkAddress:C0A8021F, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882a7e06, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:68ea2d4c-e118-402d-94a7-654a840d05f7].
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Previously found bridge discovered
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Discovered bridge 0017882A7E06 (192.168.2.31)
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Discovery Response is [devicetype:04, mac:0017882A7E06, networkAddress:C0A8021F, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-0017882a7e06, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:null, hub:68ea2d4c-e118-402d-94a7-654a840d05f7].
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Bridges Linked MAC 28C68EFE1D5F
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Bridges Linked IP 192.168.2.31
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Bridge discovery sent
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:37:19: debug Sending bridge discovery.
Also when trying to switch a bulb on I get
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:40:34: debug unknown response: [[success:[/lights/20/state/transitiontime:4]], [success:[/lights/20/state/on:true]], [success:[/lights/20/state/bri:51]]]
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:40:34: debug unknown response: {http/1.1 200 ok=null, connection=close, cache-control=no-store, no-cache, must-revalidate, post-check=0, pre-check=0, access-control-allow-origin=*, pragma=no-cache, access-control-max-age=3600, content-type=application/json, expires=Mon, 1 Aug 2011 09:00:00 GMT, access-control-allow-methods=POST, GET, OPTIONS, PUT, DELETE, HEAD, access-control-allow-credentials=true, access-control-allow-headers=Content-Type}
43aec1b5-02fa-4728-a3a1-5b683138f88b  17:40:33: trace ScaleLevel( 20, true, 254 )
6f2173c2-b940-4734-a64f-81563d4afefd  17:40:33: trace Hue B Smart Lux Bulb: on()
