HI can you please share how you getting the graph on SmartTiles? Thanks
Owner : constjs
Branch : master
Hey Joel.
How do you install the HEM?
Thanks again.
I got the HEM to install, how do I get the network ID?
Hang on sec @eric_james. Why do you need the network ID?
All you need to do is follow the instructions with ST and Aeonâs documentation to include the device to SmartThings, and then you edit the device to use the new device handler.
@eric_james, those screenshots do not look right at all. I donât even know what the second screenshot is from, but it looks like the first one is from the original device handler provided by ST, not mine.
Did you install my device handler? And did you follow Joelâs steps in post 78 up above?
Did you include the device to your hub?
I FREAKING LOVE YOU, It works!!!
Thanks for all your hark work.
Minor change:
01-20-2017 : Removed the check for 0w, but still donât allow negative values. Also removed all rounding, which now displays 3 positions right of the decimal.
Works great looks fantastic. I think you are correct about the dual reading DH it nis the IOS rendering problem. Those I contacted that have it working are on Android.
Yep, I saw your replies. Are you sure you donât want to come back to the dark side? ![]()
Naaaa! Like my Apple products. I just installed an Android emulator to see if I can load the SmartThings app and try my hand at getting it to work. The program is called BlueStacks Emulator. It Found SmartThings mobile but my network protection that was installed here is very curious about everything. Talk about artificial intelligence, this is just dumb. I am forced to run it, and there is no opting out.
@johnconstantelo I just finished installing my last two HEM V1s in my system. As it is now I enter the cost per KWH once a month when my billing cycle is up. Not accurate as it doesnât say what that month will cost per KWH. But that isnât the problem. I now do this four times one time for each HEM. Is there a way of entering the cost once and make it universal across all devices? Still canât get the dual reading clamps to work. Iâll leave it for the experts.
Need to get some convoluted tubing for that!
I plan on getting Plastic wire track with 90 degree and Ts to finish it off. Just havenât had the chance to get it.
With something like this USB wall charger you could eliminate the wire to hub
⌠http://a.co/6ZsPlxR
I have a v1⌠Not using battery power but my device shows 0%âŚis there a fix to that?
Yes install the DH that says âNo Batteryâ do a search. In the config for that unit change the battery reporting last item to 65000.
https://raw.githubusercontent.com/constjs/jcdevhandlers/master/devicetypes/jscgs350/my-aeon-home-energy-monitor-no-battery.src/my-aeon-home-energy-monitor-no-battery.groovy
Nice idea but that is $20.00 mine was free.
