vinodnx
(Vinod)
January 31, 2020, 9:10pm
1
Please help me friend , I can not see my repo in GitHub Repository integration. Please help me
Brad_ST
(Brad)
January 31, 2020, 9:27pm
2
The repo has to have a particular folder structure for the integration with the ST IDE to work. That repo doesn’t look like it has it.
vinodnx
(Vinod)
February 1, 2020, 12:14am
4
Hello friends,
Thanks for your reply. Do you have any video or link. I saw some other they are same as mine.
Regards
Brad_ST
(Brad)
February 1, 2020, 3:05am
6
I looked closer. orangebucket is correct. I believe there is an issue with your file structure which is preventing the file from showing when you click “Update from repo”.
This thread should help:
did you move your sources to the folders as i highlighted?
if you don’t respect the file path, the github import won’t find your sources based on my experience
So your “Metering Switch Child Device”, namespace: “erocm123”, author: “Eric Maycock”
Should be in a metering-switch-child-device.src folder,not in a generic folder aeotec-zwave folder.
Have a check to: https://docs.smartthings.com/en/latest/tools-and-ide/github-integration.html
Repository structure
The repository is organized by type (SmartApps or Device Handlers) and namespace.
Each SmartApp and Device Handler should be in its own directory, named the same as the SmartApp or Device Handler, and appended with ".src" .
For SmartApps:
smartapps/<namespace>/<smartapp-name>.src/<smartapp file>.groovy
For Device Handlers:
dev…
Here is a working example:
https://github.com/dbradmit/ESP8266_Blinds/blob/master/devicetypes/hobbzey/esp8266blinds.src/esp8266blinds.groovy
vinodnx
(Vinod)
February 1, 2020, 3:45am
7
Wow Brad, thanks a lot for your help. have a nice weekend
vinodnx
(Vinod)
February 1, 2020, 5:54am
8
Now I can get repo in “My Device Handler” but not getting any Repo in “My SmartApps” section. please senior once again.
Brad_ST
(Brad)
February 3, 2020, 6:49pm
9
Is there a SmartApp in that repo? Can you link the repo?
vinodnx
(Vinod)
February 3, 2020, 7:04pm
10
Hello Brad, I tried but when i want to open the app I am getting only text in that one not any app simulator
Regards
Vinod
