did you move your sources to the folders as i highlighted?
if you don’t respect the file path, the github import won’t find your sources based on my experience
So your “Metering Switch Child Device”, namespace: “erocm123”, author: “Eric Maycock”
Should be in a metering-switch-child-device.src folder,not in a generic folder aeotec-zwave folder.
Have a check to: https://docs.smartthings.com/en/latest/tools-and-ide/github-integration.html
Repository structure
The repository is organized by type (SmartApps or Device Handlers) and namespace.
Each SmartApp and Device Handler should be in its own directory, named the same as the SmartApp or Device Handler, and appended with ".src" .
For SmartApps:
smartapps/<namespace>/<smartapp-name>.src/<smartapp file>.groovy
For Device Handlers:
devicetypes/<namespace>/<device-type-name>.src/<device handler file>.groovy
The namespace is typically your GitHub user name. When you create a SmartApp or Device Handler in the IDE, you provide a namespace, which is then populated in the definition method. This namespace will be used in the directory structure as shown above.
Important
Note that the directory names must all be lowercase and must be consistent with the namespace and the name of the Device Handler or SmartApp. In other words, the directory names must all be lowercase with non-alphanumeric characters replaced with a dash. For example, if a SmartApp has the namespace “My Apps” and the name “My First App” then the path name for it must be smartapps/my-apps/my-first-app.src/my-first-app.groovy .
Brad comment was only about the last of your DTH. Others were already skipped upon import.
