What is meant by orphaned devices?
My z-wave radio appears to be broadcasting properly.
I updated the support ticket with log info, had not heard back from them though. I also noticed if I try to add a device, that seems to wake the antenna up. I was then able to get a repair to work, from pc though, not app. Not touching anything else, until I hear back.
I am not home to fully check things outâŠthings look better - no wierd statusesâŠhowever, I still have this:
I assume the zwaveradiondetected and functional should be true?
Dave
I have tried remotely clearing out orphaned devices but I am having problems with them still being seen by HarmonyconnectâŠI have done everything I can remotely but I canât seem to get Harmony and smartthings disconnectedâŠ
Dave
WellâŠafter going through three hub power cycle + z-wave repair routines yesterday, everything seems to be back to normal. I donât know if support pushed out a fix or if the powercycling was the key but Iâll take it.
zwaveNodeID: 01
zwavePowerLevel: full
zwaveRadioDetected: true
zwaveRadioEnabled: true
zwaveRadioFunctional: true
zwaveRegion: US
zwaveSerialVersion: 4
zwaveSucID: 01
zwaveVersion: 3.83
I did not submit a support ticket so this was not something that support would have done specifically to my hub.
Same zwave issues here. Mine started about a week ago. Tried everything from power cycling to repairing network. When I replace a switch, it will work for approx. 10 minutes and then nothing. I did put in a ticket with support. They reset my zwave radio, but same problems after reset. Iâve only been with Smartthings for about 3 weeks. I love it when it works, but must admit Iâm pretty frustrated at the moment. Customer support has been great. Sending me out a new hub. Hopefully that will fix my issues, if not, Iâm running back to Vera with open arms.
Mine seems to be working properly.
outside of smart things, âOrphanâ is from the childâs point of view
In network engineering, an âorphanâ device is one that has lost contact with its âparent.â
The technical details are different for different protocols: sometimes it is used to mean a battery-powered device that has lost contact with a repeater, but still knows who the network Coordinator is.
Other times it means a device that tries to join a network and fails, so has no recorded parent.
And still other times it means a device that now needs to be moved from one network to another, so it has a recorded parent but you want to use a different one.
But these three situations are always from the end deviceâs point of view. The child device has a listed parent that it cannot find, or has no parent listed at all.
outside of smartthings, âghostâ and âzombieâ are from the network controllerâs point of view
In contrast, the term âghost deviceâ is from the controllerâs point of view. it means that there is a device in the controllerâs device table that is not actually connected to the network.
Sometimes a ghost is a duplicate that was created during a failed pairing. Sometimes itâs an entry that did not clear during a failed removal. Either of these is more likely to happen in a cloud architecture because there are actually multiple copies of the network device table, usually one in the hub and one or more in the cloud. It can also be caused by database corruption, when a device from one account shows up in the cloudâs device listing for another account.
A âzombieâ device is a ghost that keeps coming back even though you have removed it multiple times. This is almost always a synchronization problem and means that you removed it from one table but then it got restored again from another.
But SmartThings uses its own terminology
As with several other terms, SmartThings tends to make up its own definitions to avoid having to distinguish between different protocols.
So SmartThings support staff, and consequently many community members, Will use the term âorphanâ for what is more typically called âghostâ and donât use the term orphan the way it is most typically used.
So a zigbee device which fails to secure a network ID during pairing is not called an orphan in SmartThings. Itâs just called a failed pairing.
But ghosts and zombies, that is, devices which have entries in the device table even though they are not actually joined to the SmartThings network, are called âorphansâ in SmartThings support terminology. (Even though in this case itâs the parent that canât find a listed child, not the child missing a listed parent.)
SmartThings also introduced the term âchild deviceâ for a programming construct and then describes those as âorphaned devicesâ for situations where only the handlers were changed, not the device pairings themselves. It even uses the term âchild deviceâ for web services situations where there was no pairing at all.
This can all make it pretty confusing if you try to look up the term in general resources. Especially since the solutions for ghosts and orphans are different. But there it is. (Smartthings also says zwave devices have âclusters,â which they donât- â thatâs a zigbee term.)
short answer: SmartThings uses âorphanâ when there is a synchronization problem with the network address tables
But is not very consistent about how the term is used, and does not use it in the way that it is generally used in network engineering.
In the following thread, for example, a community member gives a helpful explanation of how to remove a zwave ghost device from the network device table â â but calls it an âorphanâ because thatâs what SmartThings support calls it.
Thanks much for the detailed explanation. I had a rough idea but rough ideas donât mean a lot in technical pursuits
I am also affected my Zwave radio not being functional: zwaveRadioDetected and zwave RadioFunctional are both false when I look at the hub in the IDE. Obliviously this is why trying to rebuild the zwave network is failing and why Iâm totally unable to include or excluede the hub. Have contacted support and they are looking into it but was trying to reset and remove the hub and cant even force delete the devices âŠis there any way around this? Has my Zwave failed for some reason or is this a system error?
I finally heard back from support that this is a known issue and are working to resolve. No ETA.
Has your system been stable at all? Iâm wondering if a power cycle will put things in place but that doesnât inspire confidence that it will be fixed for good.
I ended up replacing my hub as the house had become really difficult to live with - rebuilt the system from scratch and now am operational again. I wondered if a severe electrical storm the night the wave radio functions failed could have anything to do with this?
A complete pain to delete all smart apps and devices, force z-wave exclusions and reconnect one by oneâŠthe use of a minimote to exclude each -zwave device made it just about manageable.
Support managed to fix my issues. It needed more than a simple restart, repair. But I can at least say that based on my experience Support does work very well!
Please contact support if you are having any of the above issues. If you are still having these issues and have already submitted a support ticket, PM me so that I can ping the support team.
@jody.albritton, I have multiple times, get the âwere aware and working itâ but no idea what the issues are.
