I was instructed to add amazon echo as a thing on my ST app. When i go to voice control, the only option i have is google home. Any ideas?
http://status.smartthings.com/incidents/fv24x9r01ndc
Try again after this is resolved.
Also, did you try to add the ST skill in your Alexa app?
Ya, the ST skill has been added.
I will keep an eye on that uodate though.
Iâve never seen Echo / Alexa / Echo Dot etc in the Voice Control tab to add. Who told âinstructedâ you to add it?
Itâs a new option with the most recent update, I think.
We were working on another issue i was having.
Mine says itâs version 2.4.1. Whatâs the latest? I went to the play store and no update available
Iâll flag the issue with the missing Alexa entries, should be a quick fix.
However, you canât actually initiate the process from that entry and youâll want to set it up from Amazonâs end. See https://support.smartthings.com/hc/en-us/articles/205275404-How-to-connect-Amazon-Alexa-with-SmartThings for more info. Also youâll want to wait until Amazonâs issue is resolved.
Iâm running 000.017.00012 on android and am also not seeing the option to add an Amazon device. just for some more feedback.
Mine is up now.
Thanks for the data point. The marketplace is mostly independent of the Hub firmware and app.
I flagged this issue and it should be showing up now. If not, let me know!
If you toggle âAllow Alexa to access all devices and Routinesâ you can select individual switches, thermostats, and locks.
Ah, gotchya. So if i leave that toggled âonâ. Alexa will have access to everything by default?
Correct.
Ok, thank you. I must have other issues then.
Now that you have the smartapp loaded you may need to discover your devices again. If that does not work get back to us on the fan thread.
