Lots of search results out there suggest you can add an Amazon Echo/Alexa device to SmartThings – it being as simple as using + from the main screen to choosing Voice Assistant. I’ve tried both the Android and IOS SmartThings apps and Voice Assistant is not an option for me…Am I missing something? or has something changed functionality-wise within SmartThings?
I have previously added the SmartThings skill within the Alex application, I’ve even disabled and re-linked it…
Ah, the docs I was reading didn’t mention a SmartApp as part of the solution! If that’s a pre-requisite and the app is shutdown that might explain a few things…
Alexa is showing there as a linked service. I guess what I’m trying to get at is exposing the Echo to something like SharpTools, but the Echo devices aren’t showing as devices in SmartThings anywhere.
Echo device do NOT show as devices in ST since Echo Speaks was shut down.
All ST devices will show up in the Alexa app.
You can create Simulated Alexa Switches or the Beta Edge virtual switches in ST to trigger Alexa routines
