New ST user unable to configure device parameters Qubino flush dimmer
Hi all, I really need to know how to set the parameters on my Qubino flush dimmer. It seems really simple all I have to is change the configuration from a 0 to a 1.
Nowhere is there a guide (that I can find) on how to do this!!!
Can someone advise exactly how I change this elusive 0 to a 1?
Configuration parameters
Parameter no. 1 – Input 1 switch type
Available config. parameters (data type is 1 Byte DEC):
 default value 0
 0 - mono-stable switch type (push button) – button
quick press turns between previous set Dimmer value
and zero
 1 - bi-stable switch type
NOTE: Switch connected to S1 terminal is a master switch.
It activates the basic functionality of the Dimmer
Parameter no. 2 – Input 2 switch type
 default value 0
and zero
NOTE: to enable this function, Parameter 20 or Parameter
100 has to be set.
This might help:
Hello,
for these you either need the Z-Wave tweaker DH or use the DHs for the device that already contain config parameter support like @erocm1231 's handlers or mine below:
I need to put Qubino input in potentiometer 0-10v
parameter 1 . (input 1. value 2)
is it possible
thank you
