Hi,
Does anyone know if this DH works on the new Smartthings app ( not the classic)
I tried all the recommendations in the thread however the part where you go into the app after you have added the device via the IDE does not work… meaning i cannot click on the device in the app and change any settings… it just says “cannot connect” I entered the Hex IP and port in the My devices screen of the IDE, but still no joy…
Curious if anyone has gotten the ability to open the Plex app on a Sony android tv using this DTH? Looks like it’s possible based on the conversation here.
I dont see that as an available option for the service, but I may not have all the available options. I was working off of @steve.bratt original code to customize. Also have this link for it:
result will be like:
{“id”:2,“result”:[[{“maxVolume”:100,“minVolume”:0,“mute”:false,“target”:“speaker”,“volume”:0},{“maxVolume”:100,“minVolume”:0,“mute”:false,“target”:“headphone”,“volume”:30}]]}
@farhanito I had looked at adding the volume information in the past but decided not to change as this will all need to be recoded eventually for the new Smartthings app.
feel free to make the required changes and post the code. you look to know more about it than me as im no programmer and bumbled the code together using google and copy and paste.
@lopesdasilva the new Smartthings app does not currently support all custom smartapps/DTH’s. This is why they have not migrated all users. Eventually they are asking that all development move from the current groovy language to their newly supported language, so I have not made any changes to my version. As @steve.bratt had suggested, @farhanito is welcome to modify either versions with your request, and publish for others. Sorry but I haven’t had time or the need to update for my own use.
Yeah, unfortunately there was 1 DTH that had code from another developer that I must have missed and they sent the info to GitHub to shut down the entire repo… DM me and I can send you the code.
Confirmed working on my Xbr75x850e with the original request handler. One thing I noticed is the power state takes a few min to update unless I manually refresh. Is there any fix for that? I want to turn on bias lighting when the tv turns on.
There is a post to describe how to resolve the issue with the power status to be updated. Below is the comment from the original post with the details:
Note: Within the Device on the SmartThings IDE the Device Network ID for Device instance must be hex of IP address and port in the form of 00000000:0000 (i.e. 10.0.1.220:80 is 0A0001DC:0050) - if you check the logs the smart device will log the correct address that you can copy paste, once the IP address has been set. If this is not set you wont get updated on/off status. Apparently you can get the Device handler to set it but ive not been able to properly test this yet.
