New Official Integration: Samsung Multiroom Audio
You won’t be able to add the hub at all - really the Hub is just a WiFi Access point now, with a fixed name and password so that the speakers don’t need any extra info to attach. This also might explain why you’re having issues adding the speakers - but it depends if the Smartthings Hub is on the same network subnet as the speakers.
In the multiroom app, check the status to show what IPs your speakers are on. Many home networks use 192.168.1.x as the format. Now compare to what IP the Smartthings Hub is on - annoyingly it seems there isn’t a way in app to find out - but if you go to the advanced settings of your router, you can find what IP it’s on.
It should also be on an IP address where the first three numbers match (192.168.1.x) - if it doesn’t, I’d be tempted to try removing the Multiroom Hub from the equation and join your WAMs to the standard WiFi network directly.
