Yes it can. The 914 has the Smartkey feature that enables you to rekey with a tool included with the deadbolt.
http://www.kwikset.com/SmartSecurity/Re-Key-Technology.aspx
Cheers,
J
Cheers,
J
I have used this successfully on a Kwikset 910 that resisted all previous attempts to connect. Thanks!
Just got my 914. Cannot get it to pair no matter what I do. I have two other 910ās that linked with no problem. Guess Iām going to sit on it a little and try again tomorrow morning and hope for the best. Totally weird that it wonāt connect.
Make sure you got the Z-wave version if you havenāt already.
Is it okay to leave the lock connected and move the ST hub closer? Probably easier this way
I had to exclude my lock before including it into my system. I have a 916 and love it, but the exclusion is relatively common.
If you have other z-wave devices near by, you donāt need to move either the hub or the lock, unless you want to. I didnāt and was able to exclude/include with no problems.
I have 3 910sā¦and I had to do the exclusion process on 2 of them (got them from Amazon warehouse dealsā¦I think they were demo models).
I had the same issue w/ not being able to join lock initially ( I think I was out of step when trying to pair the lock).
I emailed support and they very nicely emailed me back.
"You may need to exclude it first, then connect it up to SmartThings. To exclude it, follow the directions here:
How to connect and reset a Kwikset Z-Wave lock "
I hope this is redundant but I wanted to post here so if someone needed it when searching.
Any idea if the zigbee 910 lock works with SmartThings?
Adding the codes are buggy.
I found this on this forum to manage the codes. Works great!
