I recently had the Kwikset 916 door lock installed on my SmartThings hub but somehow lost its connection to my hub once I removed my batteries. I’ve since reset the door lock and deleted it from my app. I’ve been seeing lots of posts about doing an “Exclusion” for the device and then adding it back. I’ve tried this and pressing the “A” button once (Instructions per Kwikset) doesn’t work and nothing is recognized. I’ve tried so many times I feel like giving up. A real bummer as I purchased one for another door. I don’t want to run into the same issue. This is the 916 z-wave version and I also have many z-wave plus switches acting as repeaters in the area so that shouldn’t be an issue.
Any ideas? I saw a YouTube video where the guy does the “Exclusion” and pairing to SmartThings with ease which is not my case. Any help would greatly be appreciated. Thanks
It didn’t work. It doesn’t recognize the device and the app times out.
RBoy
#10
Exclude doesn’t time out, pairing does. Are you sure you were excluding it? An exclude is initiated on the lock (after putting the hub into General Exclusion mode) and then you’ll see a message on the phone saying an unknown device was excluded.
Another way would be to reset the lock.
Also try this, reboot your hub and then try to pair it. That often helps.
Well I think I realize what the issue is. When I press A on my Kwikset it doesn’t light up like it does in a video I watched. The LED light in the middle works but not for A or B. Maybe it’s broken. Bummer
Did you get it figured out? I am in the same situation where I changed my battery and my Kwikset stopped working with SmartThings. I am unable to exclude it because it does not find it. When I try and pair it with SamrtThings it stops at 80%. Also, when I press the “A” button it does not light up. HELP please.
RBoy
#15
