New Hub - Trying to Set Up - No Luck at All
Just got a new hub - tried setting it up - it went into blinking blue then a solid blue.
I connected it directly to the router, restarted - same thing.
I hard reset it, it goes to blinking blue, then solid blue then solid green then solid blue … you get the point. I made sure the ports 11111, 443, and 39500 are open
I just can’t get it to go to set up mode.
I just clicked reset when the power was plugged in and it went into a blinking yellow/red type mode, the app then recognizes it and starts but the minute it has to configure (48%) it says - your hub has not been reset.
Anyone have any ideas? Do I have a defective unit?
Which hub? Did you try rebooting your router?
SmartThings Hub v3.
yes rebooting, hard resetting
Did you read this support article?
yes I have . I also had one before that set up no problem. Anyway - I think I’ll return it.
Thank you though.
