Neo Z Wave Plus Smart Curtain Switch: works with ST?
Hi i just see this curtain switch
₪ 108.02 20%OFF | NEO Coolcam Home Automation Z Wave Plus Smart Curtain Switch for Electric Motorized Curtain Blind Roller Shutter
https://s.click.aliexpress.com/e/L6FYH0ywn
Ineed to now if is working on st ?
It will pair. Whether it works with the standard zwave window shade device handler or not depends on the specifications.
I have one of these switches working on smartthings as a z-wave window shade.
The only problem I detected that I think is not related to dh but rather to the calibration of the device, sometimes does not rise completely is about 3 or 4 centimeters. It’s a device to keep an eye out for if you don’t want to spend a lot of money on a fibaro or aeotec, it does the same thing despite the problems with calibration. I hope that the experts in creating dh’s here in the forum can give some tips.
Hi,
I tried to pair it but each time it was detected like a simple switch and so when I use it I can only mount my roller.
Have you some information about my issue please.
you have to login to your smartthings account click on my devices and then select device and change device type to z-wave window shade
Sorry for my late answering, I just tested and it works fine now, thanks a lot for your help.
Mine also works fine, except that it seems that open and close is reversed… Any ideas? There are settings in the device to reverse the buttons (up/down button swap enable), but I don’t know how to do that with Smartthings.
As for the 3-4 cms gap I found the same issue. This was fixed by re-calibrating and keeping the button pressed a bit longer when opening the shades.
Hello Guys,
I just purchased this device and I am also facing problems with callibration. Is there any other way to fix the calibration. I tried keeping the button pressed a bit longer while calibration but worked only for the first time, then second round didn’t close completely.
Best Regards,
Catalin
