Hello. I’m trying to figure out how to water my plants automatically and can’t seem to figure it out
Here is what I have:
Outdoor raised bed garden
plantlink sensors
Zooz zwave valve connected to my outoor faucet.
I’m not using any irrigation controllers nor do i have any irrigation valves.
I’m going to use drip irrigation and connected via a hose running from the faucet to garden bed.
My goal is the following:
Once planlink sensors in the garden go into Need water state, I want to open my zooz valve and get the water going to the garden. Once sensors determine there is enough water, send a command to close the valve.
Any ideas how to accomplish this? I can’t seem to find any app that does it and doesn’t look like Rule machine supports plantlink sensors
I have plantlink installed and Rule machine. I thought this was something rule machine could do, but though the advanced rule bit. Might get time to work on it this weekend and I will let you know.
That’s because you’re using the wrong device handler to do what you want. With Kristopher Kubicki’s device handler… Yes, it is possible. With OSO’s device handler, no.
