Hi
Is there a device handler with instruction that I can use? When I try to include the Fibaro it is recognized as Aeon multi sensor and cant configure it.
thanks. I copied the code and published it and then changed the type of the device from Aeon Multisensor to Fibaro motion sensor and it only gives me motion, vibration and lux. there is also a configure icon which is not responding. No temperature and the other featurs. any fix for that?
thanks
I suggest you wait a bit. Battery powered sensors often don’t report measurements instantly but after a set time (e.g. Every 15 min)
ok, thanks
