I just bought and installed a smartthings hub and adding my first device (fibaro flood sensor) went fine.
But my troubles started when i wanted to add my second sensor, a Fibaro motion sensor.
When i try to discover the sensor it reports(?) as a Aeon Multisensor and will only display motion.
below is the raw description of the device:
zw:S type:2001 mfr:010F prod:0800 model:1001 ver:2.07 zwv:3.67 lib:03 cc:30,84,85,80,8F,56,72,86,70,8E,31,9C
I will try as soon as i get home, the problem is that i have tried to change into several different fibaro motion sensors, including a community version without any luck.
All i get is motion, battery and, updating time interval.
I dont have ver 3.2 but 2.07 and i guess very limited chances of upgrading it without a fibaro home-center.
I now understand that i needed to set the device in inclusion mode(?) at the same time as i was configuring it, i used an older device handler which might be better.
hello I am looking for the device handler for fibaro motion sensor FGMS -001 V2.4 can any one help. Its EU
on V2 Uk hub,.
i have the same problem the hub is reading it as aeon multisensor.
