Need Help. Is there an ide for a motion sensor Neo coolcam NAS-PD07 motion sensor
I have only read the title of the thread, but there exists …
@krlaframboise is behind it. That is a good thing.
It does not work.
He does not detect movement.
Does not detect temp
Install and publish the handler on that other topic if you haven’t done so already, remove the device, and join it again.
I have the same sensor and used the aeon 6 in 1 sensor handler and it work well. Obviously u don’t get uv and vibration reading. But everything else works well. U just need to tinker with the settings a bit
Hi.
Can you send me the code.
I set up Aeon Multisensor 6 and it does not work
בתאריך יום ג׳, 15 ביוני 2021, 03:56, מאת al baptiste via SmartThings Community <smartthings@discoursemail.com>:
Hello.
I can not open the link.
You have the option to send the code itself
בתאריך יום ג׳, 15 ביוני 2021, 23:25, מאת al baptiste via SmartThings Community <smartthings@discoursemail.com>:
I have the same problem. The NAS-PD07 is a Zigbee device, NOT a Z-wave. I was interested in this device as it has both battery and wired power (I’m so tired of changing batteries). So the question remains, does anyone have DH for “NAS-PD07" and not original/classic Neo coolcam motionsensor?
The NAS-PD07 I have is a Zwave device , looking for a DH as well. You have any updates since you posted?
EDIT: I changed it to the Zooz 4 in 1 and it works but obviously would like a more official one that can I could edit the parameters within this device.
