Need help finding Edge Driver for Tuya smoke sensor
Read the FAQ. It explains in detail.
FAQ: Using Tuya Zigbee Devices Directly With a SmartThings/Aeotec Hub (2024)
(You originally posted in the request drivers thread, which would’ve been the right place if your post had had all of the information that developers need, As detailed in the first post in that thread. We try really hard to keep discussion of devices in that FAQ to just two posts: one with the request, and one with a response about which driver will work. Otherwise, it just becomes unusable. :cold_sweat:
In this case, because it appears you had not read the first post, your conversation was getting into multiple posts from multiple people, so I have started a new thread for you.
I know this probably seems way overcomplicated: that’s the issue you can run into with tuya devices. Again, the FAQ will explain the details.)
