(ST Edge) Zigbee Tuya Smoke Detector
Hi,
I bought three zigbee smoke detectors and I wrote a new driver for them. The fingerprints are:
Manufacturer: _TZE200_rccxox8p Model: TS0601 (tested)
Manufacturer: _TZE200_m9skfctm Model: TS0601
If you want use the driver, it is available on my channel
I used the data point information that I found on kkossev’s driver for Hubitat Elevation Many thanks again.
The driver has several capabilities like, smoke, hardware fault, silence alarm, … The smoke concentration is supposedly in ppm but I believe it is a percentage. I have never seen it go over 100 in my tests. The device only reports battery status when it is in test or smoke mode, so you can perform a test once a month as recommended by the manufacturer.
I hope you like it.
Javi.
22/03/2025 added Manufacturer: _TZE284_rccxox8p Model: TS0601
02/04/2025 added Manufacturer: _TZE284_0zaf1cr8 Model: TS0601
Would it be possible to add this Tuya ZigBee smoke detector to your driver?
Model TS0205
Manufacturer Code _TZ3210_up3pngle
Hi Paul Oliver,
I think your device doesn’t use the tuya private cluster 0xEF00, and my driver is for that cluster.
Fortunately, you can use the Mariano’s Zigbee Smoke/CO Detector Mc driver, Post Requests for Zigbee Edge Drivers Here (community-created) - #1359 by Mariano_Colmenarejo
Thanks,
Javi.
Maybe this?
https://developer.smartthings.com/capabilities/airQualitySensor
Hi otivax, thanks for the driver, but I’m having issues selecting the driver and hoping you can please assist. I have purchased the same smoke detector from your link on aliexpress, with same model “TS0601”, but it seems the manufacturer code is now slightly different “_TZE284_rccxox8p”. Could this be the issue preventing me from changing the driver? (Using an aeotec smart hub). Thank you
The ZigBee Smoke/CO Detector Mc driver might work.
hey Paul_Oliver, thank you for the suggestion. I just tried it from Mariano’s drivers, but it doesn’t seem to work either. Are you using a smoke detector that is compatible with ZigBee Smoke/CO Detector Mc? If so, could you please proved a link. Cheers
Here are the fingerprints of mine. It is over a year old from AliExpress, so the fingerprints may have changed. See link below screenshot.
https://a.aliexpress.com/_mqV3b9l
Hi @huuhaa
I need to check if your device has the same clusters and Tuya datapoints.
Please, can you install Mariano’s Thing driver and post a screen capture of your device?
Thank you,
Javi.
Thank you Paul_Oliver
Hi otivax,
Thank you for your reply. Is this what you were after? Thanks, huuhaa
Hi huuhaa,
I added the fingerprint of your device TS0601 _TZE284_rccox8p. I found it uses the same datapoints as mine.
Please, try it and let us know if it works for you.
Thank you,
Javi.
Hi otivax,
Thank you soo much for that, much appreciated. I tried it but, still doesn’t seem to work. Can you please confirm the device code, as above you have written a slightly different code (i think you may have missed an “x”):
“_TZE284_rccox8p” instead of “_TZE284_rccxox8p”
Thank you, huuhaa
Hi huuhaa,
I corrected the fingerprint, manufacturer: _TZE284_rccxox8p
Sorry, my vision is not good as it used to be :face_with_spiral_eyes:
Thank you,
Javi.
Hi Javi,
Thanks for the adjustment. But I am still unable to select the driver. Don’t worry too much about it if it is a lot of hassle. Thank you again for your time.
Kind regards, huuhaa.
Hi huuhaa,
Please, check the driver version. It should be 2025-03-20T18:30:52.985245918
You can install other driver like zigbee thing and then reinstall this driver.
Thank you,
Javi.
Hey Javi,
Oh, i think that’s where i went wrong. How do i get the latest driver from you? I have “2024-04-11T16:55:06.242330485”, if i delete it and then go back to your channel and press install again for “zigbee tuya smoke detector Otivax”, it reinstalls the same one.
Thank you, huuhaa
Hi huuhaa,
I uploaded the driver again. Now, the version is 2025-03-22T09:48:34.61318123.
You may have to wait several hours for the latest version.
Thank you,
Javi.
Hi Javi,
Its all working perfectly now :grinning_face:. Thank you soo much for your time, I really appreciate it.
