Need a new SmartApp
Can someone point me the right directions to building a Smartthings app that sends simple commands like: ```
curl -XPOST -d 01 10.0.0.10:8181/zones/16/pr
the only thing that will change here are the “16” and the “pr”
This is for a Whole House audio app from Monoprice.
Hi there! you can easily build a SmartApp using the ST NodeJS SDK, to start learning about it, here’s a step-by-step tutorial:
How would you trigger those commands?
It would just be the curl command to the web link. I can run them from a command prompt.
There is a api that is built then build a web app that points to it.
The example:
The “16” is the Zone the “pr” is the Power On Command
You could probably use webCoRE to have this http post command issued based on whatever trigger/condition you’d like.
