It looks like Nanoleaf 5.1.45 firmware has arrived for matter over thread devices.
It’s a bit of a pig to install/update. I’d allow around 5 to 10 minutes per device.each update needed to be applied manually using the Nanoleaf app, updates don’t appear to come via ST. I had 12 devices to update, 2 had extra issues (Nanoleaf app thought they were on a different thread channel to reality). For those two I had to delete and re-add those, on both Nanoleaf and st apps, and then fix the broken routines.
The update is done via Bluetooth; it works within a few meters. An “Update all” button is available. You need to close the application and relaunch it for the thread icon to reappear.
Update all isn’t practical unless all devices are in close proximity and all connected via Bluetooth simultaneously. That’s not possible for my setup with brick internal walls. I also found it failed if the Bluetooth signal was connected but weak.
Two of my bulbs updated fine.
The third one has been struggling to take the update.
Tried with the Nanoleaf app and Home Assistant - not working with either.
