Word of warning, this is very noob friendly. So, those that are more seasoned, be warned!
Parts needed:
- AL624 Low Voltage AC->DC Power Adapter - $11 + shipping
- Fortrezz MIMOlite - $59.99
- Scrap 24 gauge solid core wire - local hardware store
Total Cost: ~$75.
SmartThings Necessities:
First, kudos go to @gorf for creating the initial device type I used. It is his code that I slightly modified to work best for me.
Login to https://graph.api.smartthings.com/ and click the “My Device Types” tab
Click the green “Create New Device Type” button in the top right of the screen
On the next page, select the middle option “From Code”
Paste the following code:
/**- MIMOLite Doorbell
metadata {
definition (name: “MIMOLite Doorbell”, namespace: “NTDCS”, author: “Adam Newcomb”) {
capability “Contact Sensor”
capability “Refresh”
capability “Configuration”
//uncomment for switch
capability “Polling”
capability “Switch”
simulator {
// reply messages
reply “2001FF,delay 100,2502”: “command: 2503, payload: FF”
reply “200100,delay 100,2502”: “command: 2503, payload: 00”// status messages status "open": "command: 2001, payload: FF" status "closed": "command: 2001, payload: 00" //uncomment for switch /* status "on": "command: 2003, payload: FF" status "off": "command: 2003, payload: 00" */ } tiles { standardTile("contact", "device.contact", inactiveLabel: false) { state "open", label: "DingDong!", icon: "st.security.alarm.alarm", backgroundColor: "#ffa81e" state "closed", label: " ", icon: "st.security.alarm.clear", backgroundColor: "#79b821" } standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") { state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh" } //uncomment for switch /* standardTile("switch", "device.switch", canChangeBackground: true, canChangeIcon: true, inactiveLabel: false) { state "off", label: '${name}', action: "switch.on", icon: "st.switches.switch.off", backgroundColor: "#ffffff" state "on", label: '${name}', action: "switch.off", icon: "st.switches.switch.on", backgroundColor: "#ffa81e" } */ valueTile("voltage", "device.voltage") { state("voltage", label:'${currentValue}v', unit:"ADC") } main (["contact"]) //uncomment for switch details(["contact", "voltage", "refresh", "power" /* , "switch" */]) }}
def result = null def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x30: 1, 0x70: 1, 0x31: 3, 0x71: 1]) if (cmd) { result = zwaveEvent(cmd) log.debug "parse cmd: '${cmd}' to result: '${result.inspect()}'" } else { log.debug "parse failed for event: '${description}'" } result}
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
log.debug “zwaveEvent SensorBinaryReport: ‘${cmd}’”
sensorValueEvent(cmd.sensorValue)
}def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd)
//BUGBUG_NOTE: this is the event that gets sent from simluated messages and also if subscribed to association group 1
log.debug “zwaveEvent BasicSet: ‘${cmd}’”
sensorValueEvent(cmd.value)
}def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
log.debug “zwaveEvent SensorMultilevelReport: ‘${cmd}’”createEvent( name: "voltage", isStateChange:true, value:cmd.scaledSensorValue,descriptionText: "${device.displayName} measured voltage in ADC Counts")}
def zwaveEvent(physicalgraph.zwave.commands.alarmv1.AlarmReport cmd)
log.debug “zwaveEvent AlarmReport: ‘${cmd}’”switch (cmd.alarmType) { case 8: def map = [ name: "power", isStateChange:true] if (cmd.alarmLevel){ map.value="off" map.descriptionText = "${device.displayName} lost power" } else { map.value="on" map.descriptionText = "${device.displayName} has power" } createEvent(map) break; default: [:] break; }}
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
log.debug “zwaveEvent SwitchBinaryReport: ‘${cmd}’”
switchValueEvent(cmd.value)
}def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
log.debug “zwaveEvent BasicReport: ‘${cmd}’”switchValueEvent(cmd.value)}
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug “zwaveEvent ConfigurationReport: ‘${cmd}’”
}def zwaveEvent(physicalgraph.zwave.commands.associationv2.AssociationReport cmd) {
cmd.nodeId.each({log.debug “AssociationReport: ‘${cmd}’, hub: ‘$zwaveHubNodeId’ reports nodeId: ‘it' is associated in group: '{cmd.groupingIdentifier}’”})
log.debug “zwaveEvent Command not Handled: ‘${cmd}’”
// Handles all Z-Wave commands we aren’t interested in
}private sensorValueEvent(Short value) {
def result = [] if (value) { log.debug "Open sensor value event: $value" result << createEvent(name: "contact", value: "open", descriptionText: "$device.displayName is open", isStateChange:true ) } else { log.debug "Closed sensor value event: $value" result << createEvent(name: "contact", value: "closed", descriptionText: "$device.displayName is closed", isStateChange:true) } result}
private switchValueEvent(Short value)
createEvent([name: “switch”, value: value ? “on” : “off”, isStateChange:true ])
}def refresh() {
log.debug “executing ‘refresh’”delayBetween([ zwave.configurationV1.configurationGet(parameterNumber:3).format(), zwave.configurationV1.configurationGet(parameterNumber:4).format(), zwave.configurationV1.configurationGet(parameterNumber:5).format(), zwave.configurationV1.configurationGet(parameterNumber:6).format(), zwave.configurationV1.configurationGet(parameterNumber:7).format(), zwave.configurationV1.configurationGet(parameterNumber:8).format(), zwave.configurationV1.configurationGet(parameterNumber:9).format(), zwave.configurationV1.configurationGet(parameterNumber:11).format(), zwave.associationV1.associationGet(groupingIdentifier:1).format(), zwave.associationV1.associationGet(groupingIdentifier:2).format(), zwave.associationV1.associationGet(groupingIdentifier:3).format(), zwave.associationV1.associationGet(groupingIdentifier:4).format(), zwave.associationV1.associationGet(groupingIdentifier:5).format(), zwave.switchBinaryV1.switchBinaryGet().format(), zwave.alarmV1.alarmGet(alarmType:8).format(), zwave.sensorMultilevelV3.sensorMultilevelGet().format() ],100)}
// handle commands
def configure() {
log.debug “executing ‘configure’”/* 8v=11000101 = 197 7v=11000001 = 193 4v=2741=10101011 = 171 5v=2892=10110100 = 180 .5v=631=00100111=39 2v=2062=10000000=128 24v=11101000 = 232 23v=11100111 = 231 1.5v=1687=01101001=105 1.25v=1433=01011001=89 1.125=1306=01010001=81 1v=1179=01001001=73 */ def cmd = delayBetween([ //zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, configurationValue: [1]).format(), // clear pulse meter counts zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, configurationValue: [1]).format(), // sig 1 triggers relay zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, configurationValue: [100]).format(), // lower threshold, high zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, configurationValue: [39]).format(), // lower threshold, low zwave.configurationV1.configurationSet(parameterNumber: 6, size: 1, configurationValue: [232]).format(), // upper threshold, high zwave.configurationV1.configurationSet(parameterNumber: 7, size: 1, configurationValue: [231]).format(), // upper threshold, low zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, configurationValue: [1]).format(), // set to analog, below bounds zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, configurationValue: [255]).format(), // disable periodic reports zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, configurationValue: [0]).format(), // momentary relay zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId).format(), //subscribe to basic sets on sig1 zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId).format(), //subscribe to basic multisensorreports zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:zwaveHubNodeId).format(), //subscribe to power alarm zwave.associationV1.associationRemove(groupingIdentifier:4, nodeId:zwaveHubNodeId).format(), //unsubscribe from binary sensor reports zwave.associationV1.associationRemove(groupingIdentifier:5, nodeId:zwaveHubNodeId).format() //unsubscribe from pulse meter events ],100) //associationRemove}
def poll() {
// If you add the Polling capability to your device type, this command will be called approximately
// every 5 minutes to check the device’s state
//zwave.basicV1.basicGet().format()
}def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
],100)
}def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
],100)
Click the Save button in the top right of the box you just pasted the code into
Click Publish -> For Me
7 ) Now that the software/code side of things is done, we need to associate the Mimolite to your ST hub and change what it auto detected as the MIMOlite’s device type. Keep reading!
Temporarily power the MIMOlite by using the included AC/DC adapter and add it to your hub. It will show up as a Zwave switch, but we will change that!
Now that the MIMOlite is added to your ST, go back into where you were copying/pasting the code in step 4 and click “My Devices”. You should see a new one called “Zwave Switch”, so click on it to open the device, then the red “Edit” button at the bottom.
Rename the device and label to something more logical. I named mine “Doorbell Sensor” for both. Then, and this is important, we need to change the “Type” dropdown to “MIMOlite Doorbell”, which is what we created in the editor in step 4 as well.
Ditch the wall wart adapter and wire the AL624 from the doorbell. Then, wire the AL624 to the MIMOlite. See pictures (worth a thousand words)
(White and black wires are what I’m trying to highlight here)
(Red and white wires are what I’m trying to highlight below)
- I used the “Notify Me When” smartapp. You can find it on your phone by:
- Click the (+) symbol at the bottom of your SmartThings app (you may have to swipe down)
- Scroll right until you are at the “More” section
- Select the Convenience section and scroll down to "Get a push notification or text message when any of a variety of SmartThings is activated…The icon is a set of brown french doors and titled “Notify me When by SmartThings”.
- Configure it so that the “Contact Opens” section uses the Doorbell Sensor and optionally specify if you want it to notify you via Push or Push/SMS.
You’re done! Be sure and enclose the AL624 in some sort of project box.
Hope this helps!
