I have 1 Semi-old hardwired security system reporting to a monitoring company and
1 Smartthings Security System with a few motion sensors reporting to my phone
I wanted to merge the two ie have security alarm reported by smartthings translate to a security alarm of the hardwired system and have the security alarm reported by Hardwired system translate to a smarthings alarm.
Steps:
Free up a zone on Hardwired system: I did this by connecting 2 zones (zone 2 and 5) in series ie. twisting together common of Zone 2 and Zone wire of Zone 5. This freed up zone 5
Set up a device handler for mimolite. (Pasting my modified device handler with a lot of configurable options) at the end of this post. Then pair mimolite with smarthings
Set up a security rule to turn on Mimolite switch when a motion sensor is triggered
Send Smartthings alarm event to Hardwired System: Connect the NC of Mimolite to Zone 5 pin and Common to common pin. This will trigger the alarm when Mimolite switch is turned on.
Send Hardwired security alarm event to Smartthings: Connect the Sig+ to Bell+ in alarm panel and Sig- to Bell- in alarm pannel
Set up a custom rule to monitor open/close sensor of mimolite (which will be opened when the bell on harwired panel goes off)
Measure the open and closed voltage across bell terminals of hardwired system. For my system it was 2.5v and 13.5v. So i set my mimolite analog triggers between 3.5v and 14.5v (198,210,254,255 parameter values in mimolite), see the example code for more details.
Modify the parameters needed on the handler depending on functionality you need and voltage you see.
FortrezZ Flow Meter Interface
Copyright 2016 FortrezZ, LLC
Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0 -
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
Based on Todd Wackford’s MimoLite Garage Door Opener
metadata {
// Automatically generated. Make future change here.
definition (name: “FortrezZ MIMOlite Generic”, namespace: “fortrezz”, author: “FortrezZ, LLC”) {
capability "Configuration"
capability "Switch"
capability "Refresh"
capability "Contact Sensor"
capability “Voltage Measurement”attribute "powered", "string" command "on" command "off" fingerprint deviceId: "0x1000", inClusters: "0x72,0x86,0x71,0x30,0x31,0x35,0x70,0x85,0x25,0x03"}
simulator {
// Simulator stuff}
preferences {
//input “RelaySwitchDelay”, “decimal”, title: “Delay between relay switch on and off in seconds. Only Numbers 0 to 3.0 allowed. 0 value will remove delay and allow relay to function as a standard switch”, description: “Numbers 0 to 3.1 allowed.”, defaultValue: 0, required: false, displayDuringSetup: trueinput “Group1”, “decimal”, title: “Basic set command on Trigger/UnTrigger True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 0, required: false, displayDuringSetup: true
input “Group2”, “decimal”, title: “Periodic multiLevel sensor report based on Param9 True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 0, required: false, displayDuringSetup: true
input “Group3”, “decimal”, title: “Alarm command class report for power droupout True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 1, required: false, displayDuringSetup: true
input “Group4”, “decimal”, title: “Binary sensor command on Trigger/UnTrigger True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 1, required: false, displayDuringSetup: true
input “Group5”, “decimal”, title: “Pulse meter count based on Param9 True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 0, required: false, displayDuringSetup: trueinput “Param2”, “decimal”, title: “Reset Pulse Count True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 1, required: false, displayDuringSetup: true
input “Param3”, “decimal”, title: “Relay Triggered by SIG1 True(1)/False(0)”, description: " True(1)/False(0)", defaultValue: 0, required: false, displayDuringSetup: true
input “Param4”, “decimal”, title: “LowerThreshold High”, description: “Numbers 0 to 255 allowed.”, defaultValue: 210, required: false, displayDuringSetup: true
input “Param5”, “decimal”, title: “LowerThreshold Low”, description: “Numbers 0 to 255 allowed.”, defaultValue: 198, required: false, displayDuringSetup: true
input “Param6”, “decimal”, title: “HigherThreshold High”, description: “Numbers 0 to 255 allowed.”, defaultValue: 255, required: false, displayDuringSetup: true
input “Param7”, “decimal”, title: “HigherThreshold Low”, description: “Numbers 0 to 255 allowed.”, defaultValue: 254, required: false, displayDuringSetup: true
input “Param8_1”, “decimal”, title: “Analog(0)/Digital(1) Trigger”, description: “Analog(0)/Digital(1)”, defaultValue: 0, required: false, displayDuringSetup: true
input “Param8_0”, “decimal”, title: “Trigger Outside(0)/Between(1) Threshold”, description: “Between(1)/Outside(0)”, defaultValue: 1, required: false, displayDuringSetup: true
input “Param9”, “decimal”, title: “Periodic Reporting Interval. (Value x 10s)”, description: “Numbers 0 to 255 allowed.”, defaultValue: 30, required: false, displayDuringSetup: true
input “Param11”, “decimal”, title: “Momentary Relay Enable (Value x 100ms)”, description: " Numbers 0 to 255 allowed.", defaultValue: 0, required: false, displayDuringSetup: true
input “trigVoltage”, “decimal”, title: “Miltilevel Sensor Trigger Voltage”, description: “Numbers 0 to 16 allowed.”, defaultValue: 4, required: false, displayDuringSetup: true
}// UI tile definitions
tiles (scale: 2) {
standardTile(“switch”, “device.switch”, width: 4, height: 4, canChangeIcon: false, decoration: “flat”) {
state “on”, label: “On”, action: “off”, icon: “http://swiftlet.technology/wp-content/uploads/2016/06/Switch-On-104-edit.png”, backgroundColor: “#53a7c0"
state “off”, label: ‘Off’, action: “on”, icon: “http://swiftlet.technology/wp-content/uploads/2016/06/Switch-Off-104-edit.png”, backgroundColor: “#ffffff”
standardTile(“contact”, “device.contact”, width: 2, height: 2, inactiveLabel: false) {
state “open”, label: ‘${name}’, icon: “st.contact.contact.open”, backgroundColor: “#ffa81e"
state “closed”, label: ‘${name}’, icon: “st.contact.contact.closed”, backgroundColor: “#79b821”
standardTile(“refresh”, “device.switch”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “default”, label:’’, action:“refresh.refresh”, icon:“st.secondary.refresh”
standardTile(“powered”, “device.powered”, width: 2, height: 2, inactiveLabel: false) {
state “powerOn”, label: “Power On”, icon: “st.switches.switch.on”, backgroundColor: “#79b821"
state “powerOff”, label: “Power Off”, icon: “st.switches.switch.off”, backgroundColor: “#ffa81e”
standardTile(“configure”, “device.configure”, width: 2, height: 2, inactiveLabel: false, decoration: “flat”) {
state “configure”, label:’’, action:“configuration.configure”, icon:“st.secondary.configure”
valueTile(“voltage”, “device.voltage”, width: 2, height: 2) {
state “val”, label:’${currentValue}v’, unit:””, defaultState: true
valueTile(“voltageCounts”, “device.voltageCounts”, width: 2, height: 2) {
state “val”, label:’${currentValue}’, unit:”", defaultState: true
main ([“switch”])
details([“switch”, “contact”, “voltage”, “powered”, “refresh”,“configure”])
log.debug “description is: ${description}”def result = null def cmd = zwave.parse(description, [0x20: 1, 0x84: 1, 0x30: 1, 0x70: 1, 0x31: 5]) log.debug "command value is: $cmd.CMD" if (cmd.CMD == "7105") { //Mimo sent a power loss report log.debug "Device lost power" sendEvent(name: "powered", value: "powerOff", descriptionText: "$device.displayName lost power") } else { sendEvent(name: "powered", value: "powerOn", descriptionText: "$device.displayName regained power") } //log.debug "${device.currentValue('contact')}" // debug message to make sure the contact tile is working if (cmd) { log.debug "Creating Event :$cmd.CMD" result = createEvent(zwaveEvent(cmd)) } log.debug "Parse returned ${result?.descriptionText} $cmd.CMD" return result}
def updated() {
log.debug "Settings Updated…"
configure()
}def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug “zwaveEvent ConfigurationReport: ‘${cmd}’”
}//notes about zwaveEvents:
// these are special overloaded functions which MUST be returned with a map similar to (return [name: “switch”, value: “on”])
// not doing so will produce a null on the parse function, this will mess you up in the future.
// Perhaps can use ‘createEvent()’ and return that as long as a map is inside it.
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
log.debug "switchBinaryReport ${cmd}"
if (cmd.value) // if the switch is on it will not be 0, so on = true
return [name: “switch”, value: “on”] // change switch value to on
else // if the switch sensor report says its off then do…
return [name: “switch”, value: “off”] // change switch value to off
// working on next for the analogue and digital stuff.
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) // basic set is essentially our digital sensor for SIG1
log.debug “sent a BasicSet ${cmd}”
//this may not be working, but not using this
zwave.sensorMultilevelV5.sensorMultilevelGet().format()
return [name: “powered”, value: “powerOn”]
}def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv1.SensorBinaryReport cmd)
log.debug "sent a sensorBinaryReport ${cmd}"
if (cmd.sensorValue) // if the switch is on it will not be 0, so on = true
return [name: “contact”, value: “open”] // change switch value to on
return [name: “contact”, value: “closed”] // change switch value to off
}def zwaveEvent (physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) // sensorMultilevelReport is used to report the value of the analog voltage for SIG1
log.debug "sent a SensorMultilevelReport"
def ADCvalue = cmd.scaledSensorValue
sendEvent(name: “voltageCounts”, value: ADCvalue)def mapp = CalculateVoltage(cmd.scaledSensorValue) if (mapp.value > trigVoltage) { sendEvent(name: "voltage", value: mapp.value) return [name: "contact", value: "open"] } if (mapp.value < trigVoltage) { sendEvent(name: "voltage", value: mapp.value) return [name: "contact", value: "closed"] }}
// Handles all Z-Wave commands we aren’t interested in
log.debug(“Un-parsed Z-Wave message ${cmd}”)
}def CalculateVoltage(ADCvalue)
def map = [:]def volt = (((1.5338*(10**-16))*(ADCvalue**5)) - ((1.2630*(10**-12))*(ADCvalue**4)) + ((3.8111*(10**-9))*(ADCvalue**3)) - ((4.7739*(10**-6))*(ADCvalue**2)) + ((2.8558*(10**-3))*(ADCvalue)) - (2.2721*(10**-2))) //def volt = (((3.19*(10**-16))*(ADCvalue**5)) - ((2.18*(10**-12))*(ADCvalue**4)) + ((5.47*(10**-9))*(ADCvalue**3)) - ((5.68*(10**-6))*(ADCvalue**2)) + (0.0028*ADCvalue) - (0.0293)) //log.debug "$cmd.scale $cmd.precision $cmd.size $cmd.sensorType $cmd.sensorValue $cmd.scaledSensorValue" def voltResult = volt.round(1)// + "v" map.name = "voltage" map.value = voltResult map.unit = "v" return map}
def configure() {
def triggerMapping = Param3.toInteger()
def lowerhigh = Param4.toInteger()
def lowerlow = Param5.toInteger()
def higherhigh = Param6.toInteger()
def higherlow = Param7.toInteger()
def inputFlags = (Param8_1.toInteger()*2) + Param8_0.toInteger()
def periodicInterval = Param9.toInteger()
def momentartRelay = Param11.toInteger()
def cmds = []//Config Parameters if (Param2 == 1) { log.debug "Param2:Clear" cmds << zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, configurationValue:[1]).format() // clear pulse meter counts } log.debug "Param3:$triggerMapping" cmds << zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, configurationValue:[triggerMapping]).format() // sig 1 triggers relay //no trigger log.debug "Param4:$lowerhigh" cmds << zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, configurationValue:[lowerhigh]).format() // lower threshold, high log.debug "Param5:$lowerlow" cmds << zwave.configurationV1.configurationSet(parameterNumber: 5, size: 1, configurationValue:[lowerlow]).format() // lower threshold, low log.debug "Param6:$higherhigh" cmds << zwave.configurationV1.configurationSet(parameterNumber: 6, size: 1, configurationValue:[higherhigh]).format() // upper threshold, high log.debug "Param7:$higherlow" cmds << zwave.configurationV1.configurationSet(parameterNumber: 7, size: 1, configurationValue:[higherlow]).format() // upper threshold, low log.debug "Param8:$inputFlags" cmds << zwave.configurationV1.configurationSet(parameterNumber: 8, size: 1, configurationValue:[inputFlags]).format() // set to analog, below bounds log.debug "Param9:$periodicInterval" cmds << zwave.configurationV1.configurationSet(parameterNumber: 9, size: 1, configurationValue:[periodicInterval]).format() // disable periodic reports //enable 10 sec log.debug "Param11:$momentartRelay" cmds << zwave.configurationV1.configurationSet(parameterNumber: 11, size: 1, configurationValue:[momentartRelay]).format() // momentary relay //no delay //Association Groups if (Group1 == 1) { log.debug "Group1:On" cmds << zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:zwaveHubNodeId).format() //subscribe to basic sets on sig1 } else { log.debug "Group1:Off" cmds << zwave.associationV1.associationRemove(groupingIdentifier:1, nodeId:zwaveHubNodeId).format() } if (Group2 == 1) { log.debug "Group2:On" cmds << zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:zwaveHubNodeId).format() //periodic multilevel reports on sig1 } else { log.debug "Group2:Off" cmds << zwave.associationV1.associationRemove(groupingIdentifier:2, nodeId:zwaveHubNodeId).format() } if (Group3 == 1) { log.debug "Group3:On" cmds << zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:zwaveHubNodeId).format() //power disconnect } else { log.debug "Group3:Off" cmds << zwave.associationV1.associationRemove(groupingIdentifier:3, nodeId:zwaveHubNodeId).format() } if (Group4 == 1) { log.debug "Group4:On" cmds << zwave.associationV1.associationSet(groupingIdentifier:4, nodeId:zwaveHubNodeId).format() //subscribe to binary report on sig1 } else { log.debug "Group4:Off" cmds << zwave.associationV1.associationRemove(groupingIdentifier:5, nodeId:zwaveHubNodeId).format() } if (Group5 == 1) { log.debug "Group5:On" cmds << zwave.associationV1.associationSet(groupingIdentifier:5, nodeId:zwaveHubNodeId).format() //subscribe to pulse counts on sig1 } else { log.debug "Group5:Off" cmds << zwave.associationV1.associationRemove(groupingIdentifier:5, nodeId:zwaveHubNodeId).format() } log.debug "Requesting switch binary report" cmds << zwave.switchBinaryV1.switchBinaryGet().format() log.debug "Requesting multisensor report" cmds << zwave.sensorMultilevelV5.sensorMultilevelGet().format() delayBetween(cmds, 500)}
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(), // physically changes the relay from on to off and requests a report of the relay
refresh()// to make sure that it changed (the report is used elsewhere, look for switchBinaryReport()
}def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(), // physically changes the relay from on to off and requests a report of the relay
}def refresh() {
log.debug “REFRESH!”def cmds = [] log.debug "Requesting multisensor report" cmds << zwave.switchBinaryV1.switchBinaryGet().format() cmds << zwave.sensorMultilevelV5.sensorMultilevelGet().format() delayBetween(cmds, 500)}
