First post and new to ST and integrations. So bear with me please…
Making good progress on setting up all the handlers and app for MyQ lite (I think) as well as added the tilt sensor to ST. However I cannot figure out how to get the tilt sensor to be associated with the MyQ Lite app.
If I go to Automations And click on the MyQ Lite app it shows garage door opener, garage door closer and garage door (no sensor). If I click on Tap to modify my devices I see
Garage door contact sensor (no device found). I don’t see anywhere to select the tilt sensor that shows as a device in ST
Do you remember which device handler you installed in IDE for MyQ? If you had previously installed and set it up with the no sensor device handler, you would need to install the sensor device handler for MyQ.
Thanks for the fast reply. The sensor was added after device handlers installed so I took your suggestion and deleted the device handler: MyQ Garage Door Opener and then added it back in.
in the MyQ Lite app I still find no place to locate the sensor.
I’m not sure if there’s a conflict as ’ have the other device handler for non-sensor also. I tried deleting that and it said it’s in use and would not delete. I’m also thinking this is allowing me to open/close the garage door with ST so i’d like to keep it if possible.
I am thinking you may want to go back to the main screen of the MyQ app, go to the bottom and choose uninstall. Then create a fresh install… choose the garage door again and see if the sensor field then shows.
OK slight pogress. The tilt sensor was the one suggested on the RBoy Apps page (developer).
Ecolink Intelligent Technology Z-Wave Garage Door Tilt Sensor, White (TILT-ZWAVE2-ECO)
Definitely a pain to adopt into ST once added I had to edit the name etc.
I went into the device list in IDE and selected GARAGE DOOR and edited and changed the type from the non sensor device manager to “MyQ Garage Door Opener” which is the sensor version.
Now i have 2 MyQ Lite apps in automations which I can clean up later as needed. I ran the new one and it allowed me to choose “Garage Door” as contact sensor. There were no other options for the tilt sensor.
