Does anybody know if this works instead?
I just got my zirtsi
Do I still need to the DTH or is it direct connectivity
If I still need to add the codes, the second code is not working, is there an update to it or something ?
will it show me the current status of my blind, shutter if I used the remote? is there a stop button?
sorry for blabbing iām just excited
Hey guys, does anbody know if you can now the current state of the blind or awning ( if its 50%, open or closed) with tahoma box or anythings else?
I mean, it seems you dont know the current state of the blind with the zrtsi bridge but maybe there is another option?
I live in europe and somfy dosent sell here the zrtsi bridge, also even if i buy it there it probably wont work because of z-wave frequency. they sell a usb key dongle thats its meant to connect to tahoma box, anyone tried that?
I donāt think so because the Somfy RTS motors donāt really send/reply to any commands. It only receives so it would be down to the device sending the command to keep track of the last position; which can be wrong if the blinds or shades were controlled manually.
It is possible for IO blinds, not for RTS.
The [OBSOLETE] TaHomaĀ® by Somfy integration I made for TaHoma handles position for IO blinds. It is a cloud to cloud integration, doesnāt require additional hardware.
Hello, i recently installed somfy zwave shades.
in smartthings, there is a round green battery icon. Does this accurately measure battery life remaining?
how do i get the shades to show up in my google home app so i can control them by voice? I have it working now but through a complex work around (had to set up a virtual switch in smartthings that is mirrored to shades. The shades donāt show up in google home but the virtual switch and my other zwave switches do). The work around is fine but using this method i canāt use google home to set them to a percentage open/closed - only all the way open or all the way closed.
Are you talking about the z-wave integrated motors? If so I would move the discussion here, this thread is more for the Somfy RTS motors and their bridge:
Also to get them to show up in Google Home you need to go into the IDE to switch the device type to a dimmer switch.
Ok, thanks for the tips!!
Anyone been successful using homebridge to control the Somfy / Graber blinds? I installed homebridge on a Raspberry Pi and I used a Smartthings device handler to load everything that was in Smartthings ā¦ it treats them all like a dimmer, which is fine, but I can only seem to get the blinds to go up, not down. Curious if others have had any luck and which handler you are using in both ST and homebridge.
Hey Eric, for the z-wave shades itās better to ask on this thread, also which DH are you using?
I created both device handlers for zrtsii and shades but i really donāt understand the next step?
Just put the Zrtsii into including mode and look for devices in ST app?
Because it always fails
Does it need to be very close to the hub?
Please help
My Somfy blinds stopped responding to ST. They were working fine after the latest new UI app update a few days ago. So I am not suspecting it is because of the app. I have restarted the ZRSTII, restarted the ST hub and no luck. Any ideas on how to troubleshoot. This has been working fine for the past 3 years.
Check your IDE to see if the ZRTSI is receiving the commands from the hub and responding at all. It could just be the ZRTSI fell out of the z-wave network.
From the IDE logs, I can see that it is getting the commands
From the app, it shows like it is disconnected sometimes and sometimes is ok.
RTS testing works (meaning closing/opening blinds)
Another questions is, my Controller is using a Type: Z-Wave Controller. Is this correct? That is what I have been using for years.
UPDATE: End it up excluding virtual devices then controller, re-adding them, copying the smartapps from previous devices to new devices, issuing a discovery in Alexa and changing any actions in Alex and tasker to reflect new devices.
Let me know if this should be in another thread. My configuration is: Somfy roller blinds, MyLink Tablet Interface/WiFi, Davis Vantage Vue using Meteobridge, legacy SmartThings. I can control the blinds with SmartThings and have a custom device handler working with the Meteobridge (Davis Vantage). Iāve set up a test automation where I turn on a light based on an illuminance value from the Davis. The use case I want to put together is: Based on the illuminance lower the shades, Iād also like to add other variables like wind but would be happy to just get them to go down. If possible Iād like to avoid IFTTT webcore is something would consider but donāt have a clue how to control the up or down only on and off. Any thoughts?
I have two Somfy RTS remotes (a blue and gray if that matters) that control two outdoor awnings. I would like some advice, would the zWave RTDII module work best for my setup or is there another device you guys suggest?
