So I tried the new code and I still show 0/9 for windows. There are no longer any window sensors. Also, i am noticing something strange with the motion sensors. My total number of motion sensors keeps changing. For example, was 1/9 then 1/11. Very odd. Thanks again!
I’ll take another look tomorrow morning.
I tried it this morning by removing all of my windows and the device reset to 0/0.
The display issue is weird too, the numbers should be {open|active|unlocked}/{closed|inactive|locked} so they should jump a little but they should always add up to the total.
Hi Dav:
Sorry for the delayed response on this. So eventually the window sensor wen to 0/0. I understand the the numbers now. So if I have 12 motions sensors and when everything is inactive it will read 0/12 and when 1 is active it will read 1/11. Thanks
So far so good with this app. Is it possible to add Humidity levels similar to temperatures?
Pushed up a new version that supports it:
Thanks Dav, trying it right now.
This app doesn’t work with the latest android 1.7.2. Unexpected error when clicking on the preference gear. Works with 1.6 but it take really long on loading all the devices.
Unfortunately I don’t own any Android devices to test this with so I have no idea what it would be doing.
Yeah, after the android ST update. Half of my custom apps will not load probably so I guess this could have the similar background color error. Hopefully ST will fix it soon.
So I updated the smartapp and device code yesterday and I am only getting a – where the humidity average would be. Any ideas? Thanks!
Can you try looking at the live log and tapping the app icon to make it refresh to see if there are any errors? Also how many humidity sensors do you have reporting? I tested it with the 3 that I have and it showed the data.
I did not see any errors. I posted the live log below filtering on My House at a Glance. I have a total of 3 humidity sensors all coming from my Nest.
5bfa396d-825a-4e7a-8c81-38939a7000a6
9:08:40 AM:
debug
Setting power to: 1826 Watts
9:08:40 AM:
debug
There are 0 active and 12 inactive motion sensors..
9:08:40 AM:
debug
motion handler called..
9:08:33 AM:
debug
9:08:33 AM:
debug
There are 1 active and 11 inactive motion sensors..
9:08:33 AM:
debug
9:08:06 AM:
debug
9:08:02 AM:
debug
9:08:02 AM:
debug
There are 2 active and 10 inactive motion sensors..
9:08:02 AM:
debug
9:07:56 AM:
debug
9:07:56 AM:
debug
9:07:56 AM:
debug
9:07:06 AM:
debug
Setting power to: 1859 Watts
9:06:06 AM:
debug
9:05:57 AM:
debug
9:05:56 AM:
debug
9:05:56 AM:
debug
9:05:56 AM:
debug
9:05:56 AM:
debug
9:05:56 AM:
debug
9:05:48 AM:
debug
9:05:48 AM:
debug
9:05:48 AM:
debug
Did you update both the device type and the app? I don’t even see the humidity being logged out.
I am a dumb___ (fill in the blank). Forgot to turn on the humidity setting in the app itself. duh! Thanks for your help and this awesome app. It get a lot of usage out of it.
No worries, I do that all the time. As I work on these things, several times I’ve beaten my head off the desk wondering why it’s not working only to realize that I never added the devices on my phone
This is cool , many thanks for writing this app
