Multipurpose sensor and humidity
Does the multipurpose sensor I longer read humidity, on amazon it says it does. But when I change the setting in ide nothing shows up.
What’s the exact brand and model of the sensor? Different ones have different features.
Samsung SmartThings Multipurpose Sensor
There have been a couple of different models of that, but as far as I know, they all do temperature but none of them do humidity.
Do you have a link to the Amazon description?
The description for the current model says temperature, but not humidity:
https://www.amazon.com/Samsung-SmartThings-F-SS-MULT-001-F-MLT-US-2-Multipurpose/dp/B0118RQW3W
@JDRoberts is right @Derrek113116. ST use to have a temperature and humidity sensor, but it’s no longer available. PEQ may still have them.
The Aeon multisensor six Will report humidity, temperature, and vibration, but it doesn’t have a Contact sensor. So I don’t know if that’s of any interest or not.
Everspring also has a sensor which does just humidity and temperature:
Thank you jd, you always help me out that’s what I thought. looked at one of the “answers” they said yes humidity. Just wanted to make sure
Ok got it!! Now how do I make it display humidity on the home screen and not motion
Here is a slightly cheaper alternative. I have been using it since the Smartthings sensor is not available anymore (which is working great but was way overpriced for what it does).
https://www.monoprice.com/Product?p_id=15902&gclid=CjwKCAjwt8rMBRBOEiwA2F2biO6y6hsVHpP_xlMMY3KAKLtldCDkwA1c-6pyE7AGXsRIukIonPmMVxoC2-QQAvD_BwE
Or also available here:
I am using it with this device handler:
https://github.com/krlaframboise/SmartThings/blob/master/devicetypes/krlaframboise/zooz-monoprice-4-in-1-multisensor.src/zooz-monoprice-4-in-1-multisensor.groovy
In the device handler you can actually select what parameter you want as main parameter.
