Hi all.
Have any of you seen or tried this yet? I’ve been looking for a z-wave temp/humidity sensor (only) and this looks like it could fit the bill. Doesn’t appear to be working with Smartthings entirely just yet but has potential.
Hi all.
When I read the Q&A on Amazon, it stated the following:
aerQ Sensor is not yet compatible with SmartThings, but you could manually change the device handler to use “Z-Wave Water/Temp/Humidity Sensor” which should work in SmartThings IDE to get Temperature and Humidity reports. This sensor should be compatible with SmartThings in the near future.
By Aeotec Home on December 29, 2020
You have to create a new DH. I have attached a JPEG file with the customer DH that Aeotec gave to me. After you create the DH and then publish it to yourself, the Temperature and Humidity can bee added to you SmartThings app.
Thanks. What attribute does the tile display for this device handler, temp or humidity?
This device handler will give you temperature, humidity and battery for the Aeotec Temperature and Humidity sensor.
Thanks. I think what I was asking is that when you look at the tile in a room on the app you see one of the attributes; for this device/handler which is it? Temperature I assume?
Is there any chance you can upload as a plain text file? I’ve tried copy pasting from your other thread on this and no luck. Looks like the jpg isn’t the complete handler either.
Thank you!! Just got one of these sensors and the DH aeotech has on there site for the device is from 2018 and diff from what you’ve posted. Doesn’t seem to have any auto updates nor display batt level or temp correctly
I’m not really sure how to upload a txt file. Here it is just pasted into this reply.
http://www.apache.org/licenses/LICENSE-2.0
metadata {
definition(name: “Z-Wave Temp/Humidity Sensor”, namespace: “smartthings”, author: “SmartThings”, mnmn: “SmartThings”, vid: “generic-leak-5”, ocfDeviceType: “x.com.st.d.sensor.moisture”) {
capability “Water Sensor”
capability “Temperature Measurement”
capability “Relative Humidity Measurement”
capability “Tamper Alert”
capability “Battery”
capability “Sensor”
capability “Health Check”
capability “Configuration”
fingerprint mfr:"0154", prod:"0004", model:"0014", deviceJoinName: "Popp Mold Detector", mnmn: "SmartThings", vid: "aeotec-water-sensor-7-pro" //EU //Mold Detector
fingerprint mfr:"0371", prod:"0002", model:"0009", deviceJoinName: "Temperature Humidity Sensor", mnmn: "SmartThings", vid: "aeotec-water-sensor-7-pro" //EU //aerQ Sensor
fingerprint mfr:"0371", prod:"0102", model:"0009", deviceJoinName: "Temperature Humidity Sensor", mnmn: "SmartThings", vid: "aeotec-water-sensor-7-pro" //US //aerQ Sensor
tiles(scale: 2) {
multiAttributeTile(name: "water", type: "generic", width: 6, height: 4) {
tileAttribute("device.water", key: "PRIMARY_CONTROL") {
attributeState("dry", label:'${name}', icon: "st.alarm.water.dry", backgroundColor: "#ffffff")
attributeState("wet", label:'${name}', icon: "st.alarm.water.wet", backgroundColor: "#00A0DC")
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "battery", label: '${currentValue}% battery'
valueTile("humidity", "device.humidity", inactiveLabel: false, width: 2, height: 2) {
state "humidity", label: '${currentValue}% humidity', unit: ""
valueTile("temperature", "device.temperature", width: 2, height: 2) {
state("temperature", label: '${currentValue}°',
backgroundColors: [
// Celsius
[value: 0, color: "#153591"],
[value: 7, color: "#1e9cbb"],
[value: 15, color: "#90d2a7"],
[value: 23, color: "#44b621"],
[value: 28, color: "#f1d801"],
[value: 35, color: "#d04e00"],
[value: 37, color: "#bc2323"],
// Fahrenheit
[value: 40, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 95, color: "#d04e00"],
[value: 96, color: "#bc2323"]
/*valueTile("dewpoint", "device.dewpoint", width: 2, height: 2) {
state("dewpoint", label: '${currentValue}°',
backgroundColors: [
// Celsius
// Fahrenheit
valueTile("tamper", "device.tamper", height: 2, width: 2, decoration: "flat") {
state "clear", label: 'tamper clear', backgroundColor: "#ffffff"
state "detected", label: 'tampered', backgroundColor: "#ff0000"
main (["humidity", "temperature"])
details(["humidity", "temperature", "battery", "tamper"])
def installed() {
clearTamper()
response([
secure(zwave.batteryV1.batteryGet()),
“delay 500”,
secure(zwave.notificationV3.notificationGet(notificationType: 0x05)), // water
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x01)), // temperature
“delay 500”,
secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x05)), // humidity
“delay 500”,
//secure(zwave.sensorMultilevelV5.sensorMultilevelGet(sensorType: 0x0B)), // dewpoint
//“delay 500”,
secure(zwave.wakeUpV2.wakeUpNoMoreInformation())
def updated() {
configure()
def configure() {
sendEvent(name: “checkInterval”, value: 8 * 60 * 60 + 10 * 60, displayed: false, data: [protocol: “zwave”, hubHardwareId: device.hub.hardwareID])
def results =
if (description.startsWith("Err")) {
results += createEvent(descriptionText: description, displayed: true)
} else {
def cmd = zwave.parse(description)
if (cmd) {
results += zwaveEvent(cmd)
log.debug "parse() result ${results.inspect()}"
return results
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
def encapsulatedCommand = cmd.encapsulatedCommand()
if (encapsulatedCommand) {
zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def zwaveEvent(physicalgraph.zwave.commands.notificationv3.NotificationReport cmd) {
log.debug "Notification " +cmd
if (cmd.notificationType == 0x05) {
if (cmd.event == 0x01 || cmd.event == 0x02) {
sensorWaterEvent(1)
} else if (cmd.event == 0x00) {
sensorWaterEvent(0)
} else if (cmd.notificationType == 0x07) {
if (cmd.event == 0x03) {
runIn(10, clearTamper, [overwrite: true, forceForLocallyExecuting: true])
createEvent(name: “tamper”, value: “detected”, descriptionText: “$device.displayName was tampered”)
createEvent(name: “tamper”, value: “clear”)
def zwaveEvent(physicalgraph.zwave.commands.sensorbinaryv2.SensorBinaryReport cmd) {
log.debug "Sensor Binary " +cmd
return sensorWaterEvent(cmd.sensorValue)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
log.debug "BASIC " +cmd
return sensorWaterEvent(cmd.value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def zwaveEvent(physicalgraph.zwave.commands.sensoralarmv1.SensorAlarmReport cmd) {
log.debug "Sensor Alarm " +cmd
return sensorWaterEvent(cmd.sensorState)
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
def map = [name: “battery”, unit: “%”, isStateChange: true]
state.lastbatt = now()
if (cmd.batteryLevel == 0xFF) {
map.value = 1
map.descriptionText = "$device.displayName battery is low!"
} else {
map.value = cmd.batteryLevel
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv5.SensorMultilevelReport cmd) {
def map = [:]
switch (cmd.sensorType) {
case 0x01:
map.name = "temperature"
map.value = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmd.scale == 1 ? "F" : "C", cmd.precision)
map.unit = temperatureScale
break
case 0x05:
map.name = "humidity"
map.value = cmd.scaledSensorValue.toInteger()
map.unit = "%"
break
/*case 0x0B:
map.name = "dewpoint"
break*/
default:
map.descriptionText = cmd.toString()
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
def cmds =
def result = createEvent(descriptionText: “$device.displayName woke up”, isStateChange: false)
//cmds += secure(zwave.batteryV1.batteryGet())
if (!state.lastbatt || (now() - state.lastbatt) >= 10 * 60 * 60 * 1000) {
cmds += ["delay 1000",
"delay 2000"
cmds += secure(zwave.wakeUpV2.wakeUpNoMoreInformation())
[result, response(cmds)]
log.warn “Unhandled command: ${cmd}”
def sensorWaterEvent(value) {
log.debug “water event”
if (value) {
createEvent(name: “water”, value: “wet”, descriptionText: “$device.displayName detected water leakage”)
} else {
createEvent(name: “water”, value: “dry”, descriptionText: “$device.displayName detected that leakage is no longer present”)
def clearTamper() {
sendEvent(name: “tamper”, value: “clear”)
private secure(cmd) {
if (zwaveInfo.zw.contains(“s”)) {
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
} else {
cmd.format()
Could be that I’m a noob lol
Issue I’m having is with the attached screen caps - there is a “box” character in two spots…
!Here’s the dth in copy paste form from another thread.
