Hi,
I was trying to change the battery on my multi-sensor and because the brackets holding the batteries are so tight, when I attempted to insert the new batteries, one of the brackets came out. Is there a way to fix this?
Hi,
would it be possible to drop a little solder thru those small holes and get it to re-attach?
Yes, you should be able to just resolder it to the board. But I would guess the real issue is that you have the wrong batteries installed. All of my old multi use AAAA not AAA batteries. The quad A’s are a lot smaller width wise.
Thanks! My mistake I didn’t notice the AAAA
good catch… I never noticed that. Mine are also AAAA also.
