Moving to Konnected and Smartthings - trying to use ActionTiles with Alarm Arm and Disarm and the icon does not indicated Armed
The icon on ActionTile does not change color to indicate alarm set
Hi Richard,
I have the same setup (Konnected, ST and AT), so I’ll try and help, but hard to say what’s wrong without more info.
I assume your Konnected upgrade has worked, and your panel(s) are showing in the Konnected app, with all zones working and triggering?
If so, then can I ask have you linked to ST successfully and have all the zones showing in the ST app? Are they triggering and working?
What are you using to set the alarm, I guess STHM? If so, does setting the STHM arm the system successfully?
If all of that is working, then it must your AT settings - so let’s look at those if all the stuff in items 1-3 are working well, so let me know.
