I physically moved a smartthings outlet from one room to another but I’d like to change it in the software. Is there a way to do this besides deleting it re adding the outlet?
open app, go to the room it used to be in, click on settings ( gear/hamburger) . Find the plug you removed and click on the - . to remove it. Done
Open the room you moved it into, click on the settings gear, scroll down " add devices to this room" find the outlet you just removed from the other room, select it… Done
Thanks. Yeah, I know that. Was just asking if there was a way to just move it real quick in the software.
