I can’t figure out how to move thing to different room in android app 2.0.7
Is it possible ?
I assume I can in IDE but should be possible in the app right ?
Is it possible ?
You need to remove the device from the room it’s in first.
Go to the room, go to the top right menu and Edit Room, then Add/Edit devices in this room - remove the device… then do the same for the room you want to add it to except add the device
Ah…“Add/Edit Devices” looked like a label to me so I didn’t tap it to enter edit mode.
