How to i take my echo dot to my parents to set it up for the day,i have tried but no good it will not connect to there internet it says connect to Amazon xxx but thats not there.what do i do there is no hotspot i can see of or do i use my data connection on my mobile any help please thanks
I haven’t done it but it should just be a matter of connecting to their Wi-FI. Once at your parents reset the device and go through the setup procedure.
For a 1st generation their is a reset button you press with a paper clip on the 2nd gen you use the following
To reset your Echo device that has volume buttons: Press and hold the Microphone off and Volume down buttons at the same time until the light ring turns orange (about 20 seconds).
