Amazon echo dot range
Hey guys,
Purchased an amazon echo dot
Is there a certain range where the smartthings has to be in order for the echo to connect with?
Or do they sync by wifi?
I have the hub downstairs and want the echo upstairs
Its a Cloud to Cloud to basically means
Echo --> WiFi --> Your ISP --> Amazon --> SmartThings [Cloud] --> Your ISP --> WiFi --> SmartThings [Hub]
They have no connection locally, if your internet goes down - they cant talk. So if they are both on the same WiFi you will be fine :slight_smile:
Kraeg
cheers mate… another question pls… i want to have a motion sensor upstairs… but the hub is not connecting to it when i get up the stairs…
is there anything i can do pls?
thanks
Does it connect when it’s closer to the hub?
If it does; it might be a range issue or maybe something interfering with it.
If it doesn’t; remove it from SmartThings and add it again.
If that fails, contact support - they can look into your account and see what’s going on.
Kraeg
If it’s a range issue, you can buy things that will extend the range. Plug in items can be range extenders, but battery operated ones will not.
