Motion, Temp, Humidity Sensor Recommendations?
Looking for which sensors are currently working well/recommended for usage. Motion will trigger lighting action, but would like to use temp/humidity to track housing HVAC variances in different rooms/levels with adjustments I make to the duct dampers over time. Data, Data, data!
The last generation of Iris motion sensors include humidity (and temp). They pair readily and use built-in DHs, and they’re easy to get cheap on eBay. I got one to play with, still have vague intentions to pick up a couple more to cover the other bathrooms. Can’t speak to precision / accuracy but the connectivity is reliable…
Can confirm the Iris iL07 works well for me
ZooZ 4 in 1 Sensors
Monoprice 4 in 1 Sensors
