Motion Sensors - Motion not showing up in logs
I am having a hard time getting Motion Sensors to work right…
I have two types I am playing with…
Ecolink Z-wave - PIRZWAVE2-ECO * 1
Enerwave ZWN-BPC Z-wave * 3
I have been able to get them to join the z-wave network and start reporting back battery status.
Pirzwave2
Date	Source	Type	Name	Value	User	Displayed Text
2015-11-01 8:45:10.710 PM EST  7  minutes ago	DEVICE		battery	99		Furnace Room Motion Sensor battery is 99%
2015-11-01 10:14:50.852 AM EST 11 hours ago	DEVICE		battery	100		Furnace Room Motion Sensor battery is 100%
2015-10-30 2:27:03.192 AM EDT   3 days ago	DEVICE		battery	99		Furnace Room Motion Sensor battery is 99%
2015-10-29 9:50:06.920 PM EDT   3 days ago	DEVICE		battery	99		Z-Wave Door/Window Sensor battery is 99%
2015-10-29 9:50:00.790 PM EDT   3 days ago	COMMAND	        configure		configure command was sent to Z-Wave Door/Window Sensor
Zwn-bpc
Date	Source	Type	Name	Value	User	Displayed Text	Changed
2015-11-01 9:08:08.542 PM EST  10 minutes ago	DEVICE		battery	100		Garage Motion Sensor battery is 100%	true
2015-11-01 8:48:47.768 AM EST  12 hours ago	DEVICE		battery	100		Garage Motion Sensor battery is 100%	true
2015-11-01 2:55:16.667 AM EST  18 hours ago	DEVICE		battery	100		Garage Motion Sensor battery is 100%	true
2015-10-29 10:53:16.226 PM EDT  3 days ago	DEVICE		battery	100		Garage Motion Sensor battery is 100%	true
2015-10-29 9:34:47.571 PM EDT   3 days ago	DEVICE		battery	100		Z-Wave Motion Sensor battery is 100%	true
2015-10-29 9:34:40.580 PM EDT   3 days ago	COMMAND		configure		configure command was sent to Z-Wave Door/Window Sensor	true
But I can not get them to show motion or lack of motion. What am I doing wrong? I would would like to start using these motion sensors to turn on lights when you walk into a room. I see how to add them as triggers in the smart lighting app, but they never execute.
Here is the logs from the smart lighting app.
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:44:31 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:44:30 PM: debug Updated with settings: [trigger:Motion, overrideLabel:true, motionState:active, motionStops:true, action:on, motionStopsTime:5, contactState:open, lights:[Furnace Room Light], motionSensors:[Furnace Room Motion Sensor], contactCloses:false]
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:44:16 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:44:11 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:44:08 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:44:06 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:43:24 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:43:16 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:42:53 PM: trace timeBasedTrigger: false
ccf5463d-7870-468d-b04e-fbcbbf33a1dd  8:42:43 PM: trace timeBasedTrigger: false
I’ve had a similar issue the last couple of days. This seemed to fix my problem:
Motion sensor Smartthings stop working
Appologize me, I don´t like do new topic. I would like ask all of you for DTH for zigbee motion sensor Eglo 99106 EGLO CONNECT-Z SENSOR accessory
In the Smartthings is producer Awox TLSR82xx. The sensor is paired but don´t comunicate. I tried all DTHs for Motion Sensors which are available in the standard library, but without succes. Could you help me with that? Thank you.
