All,
Love the ECOLINK products for my Smartthings system as they seem to be some of the most reliable with great battery life.
But I am having an issue with one of the PIRZWAVE2.5-ECO motion detectors. It intermittently doesn’t seem to be releasing the motion status. That is, it will indicate motion, but doesn’t change back to “no motion” after the 4-minute timeout. It then gets a little out of sync until I do some moving and pausing around it again.
I’m using this for the STHM security, but I also use it to turn on one light at night. My automation will turn on the light when motion is detected and turn off the light when motion stops (usually the built-in 4-minute timeout if motion doesn’t continue). It’s not been very reliable for the light at all.
Z-wave network should be great - there are at least three mains-powered devices nearby and on the way to the hub.
Thanks if you have any thoughts!
