I have a BeSense Motion Sensor in my garage and a globe smart plug that my shop lights are plug into. In smart things I have an automation set that if my shop lights are on and the motion sensor is motionless for longer then 30 sec, to shut off my shop lights. I set a timer for 30 secs and wait to watch the lights switch to off in smartthings and nothing happens, and yes I have gone to check the garage and they are still on. Does anyone have any idea why they this automation is not working
try using smart lighting
Smart Lighting?
if available in your region…
to install, click on + (plus) in the upper right of the dashboard
choose smart app
select smart lighting.
once installed, you can access it from menu > smart apps.
you can create a rule to turn on or off the light the light based on motion
Ok I’ve got that set up we will see what happens
