More "unavailable" devices
I’m fairy new here, got the Gen 2 ST hub end of Sept and everything has worked swimmingly up until this morning. I have Samsung ST branded motion and multi sensors, Sylvania (Lightify) RGB strips, Philips Hue (hub + bulbs), and Ecobee 4.
What I’ve seen is all the ST hardware fails, but the Ecobee and Philps Hue maintain availability. ST support had me do the battery reset thing and it works for about 10 min then I see everything returning to crap. Most of the sensors are two weeks old, and one sensor is in the same room as the hub.
Reading though this thread, I’m guessing we are SOL?
In the last week I have had all my devices on a Hue bridge go “Unavailable”. No changes have been made to the Hue Bridge and accessing devices directly through the Hue bridge, bypassing the ST Hub, works fine. ST hub seems to have lost its awareness of the devices on the Hue bridge. Seems to have happened between 12/29 and 12/30/2017. --TGV
Same here. After having my system work well for the past year, I just noticed like 4-5 items go Unavailable. These are GE lightswitches, fan control, etc. What’s going on?!
Major system outage since 4:30a EST
https://status.smartthings.com
Me too, no zigwee; all powered Zwave… random “device unavailable” sometimes its even the device in the room with the hub! (~10 feet line of sight from Hub to device.)
Devices are brand new CT100 Plus Radio Thermostat Thermostats… powered with 24VAC “C” wires. NO batteries.
Nothing else on the hub than a few thermostats and they randomly report unavailable.
I have have this issue too. I looked for a plausible cause but couldn’t find one so I sent a request to tech help and I got this reply: "Dave S. (SmartThings)
Jan 7, 2:45 PM MST
Hey Jim,
Thanks for contacting SmartThings Support.
Sorry to hear you are seeing unavailable devices frequently! I know how concerning that can be.
Thankfully, I believe this to be an issue with Device Health and nothing wrong with your actual devices.
We are working on fixing an issue with Device Health where it will incorrectly mark devices as unavailable. For now, I recommend disabling Device Health and we’ll email you as soon as it is fixed.
If this does not resolve the issue please let me know!"
Update. So turning off device health only seems to mask the problem, no more white circles with red dots…
BUT
Today the thermostat in the mobile app the Master bathroom reports that the room is 5 degrees F (-15.5 C)… Which is kinda funny since it is about 40 degrees outside and the room is actually a normal 70 degrees. And the thermostat is working normally.
Curiously if I click on the Thermostat tile and then click on the SmartApps tab and then select one of the actions (I’m Back, Goodbye, Good Night, or Good Morning) and then back out without saving anything or making any changes the mobile App resets and the thermostat starts polling again. So I have figured out a way to fix this remotely and without rebooting the thermostat or the hub… It looks like the polling “health” error occurs when one of the canned Smarthings automation run
So I’m sad to report that turning off device health does not solve the problem it only masks it.
I fixed mine by removing batteries and pulling plug for a minute. Didn’t
come back immediately, but eventually.
I just installed my Smart Things devices this week. I previously used Wemo hub for my smart bulbs. This thing is pretty unreliable. Two outages this week and now all GE smart switches and cree bulbs are offline. Really ticks me off to invest in this technology only to not have it work as expected in the first week of use.
SOLVED (for me at least): A week of the same “Device Unavailable” issue. Moved the SmartThings hub away from my wireless router, to the other side of the house. Devices slowly started to repopulate their “ONLINE” status in the IDE and in the app. This morning, everything is magically working again. Get your hub away from your wireless router. Hope that works for others as well.
It’s also possible that just powering off your hub and on again, if it was for more than a few minutes, caused your Zigbee devices to remap anyway. But yes, being near the router can be an issue. I’ve strangely never had this interference problem. My ST hub is 7 inches from my router.
Mine is also less than a foot away and has been for a year without interference issues.
Another thing, depending on what gets rebooted and the timing of how long things are powered off, it’s possible that either the ST Zigbee channel on the hub changed upon startup, or rebooting the router changed what channel the 2.4ghz band is on. Troubleshooting these things 1 by 1 to isolate the actual issue can help you prevent these same issues in the future. Otherwise it will always remain a guessing game. Was it my hub distance to router, was it my 2.4ghz channel being on 1 and interfering with neighbors router, was it my Zigbee channel interfering with my wifi 2.4ghz channel (overlap), or did my Hue Bridge channel cause some sort of interference between the other two?
A lot of people, depending on equipment and setup don’t run into these issues, but for those that do experience something like this, troubleshooting all these scenarios is worth trying to track down to prevent it from happening again.
Good stuff.
Just one point on this comment though … see the first point made in the post you linked to:
“The SmartThings hub is a very inexpensive device. Its Zigbee coordinator is pretty limited compared to more expensive devices. As @Mr_Lucky said, it cannot change its Zigbee frequency, either on the fly or as a user request. Whatever it was set to at the factory is what you’re stuck with.”
So, if you want to mess with channels you need to do this on your router.
In my case I have my router channels fixed so it will not change even on a reboot. I am sure I have just gotten lucky with that channel (which I set for other reasons before I used ST) and the channel factory-set on the ST hub.
Ya, I wasn’t insinuating that you could manually change or force the Zigbee channel to change, but I know that mine has changed in the past. Whether this is from firmware upgrades, or from long power outages upon reboot or some other function on the backend that refreshes the channel.
If someone does have channel overlap between the two, you would definitely make a channel change directly on your router with respect to the 2.4ghz channel and separate it as far from where the ST Zigbee channel is set to. (Most people have Auto set for channels on all their bands - hardcoding channel 1 is usually bad as this is typically the most congested channel).
I’ve been having sensors going offline quite a bit since the latest firmware update. Pulling out/putting in the batteries does seem to fix the issue, but seems like it is happening much too frequently now.
Hi, I have only had my ST Hub since the end of December and the ST Motion Sensor very quickly started becoming Unavailable, which was resolvable by refitting the battery, but that is not viable if you are away. Eventually it packed up altogether and I had it replaced by the supplier. The new one started going offline within 2 days. My Door Sensor has also started doing the same thing. I have found the answer… I have already bought a non-Samsung motion sensor and door sensor very cheaply via Amazon from China and they work faultlessly although they do not have the extra functionality i.e. temperature.
Really Appreciating your feedback, it worked for me
