I’ll toss the code in the thread here in case others need it some day. All I really changed was the temp conversion math, maybe 5 or 5 lines. Good luck.
* Monoprice Motion Sensor - ** Fahrenheit default version **
* Capabilities: Motion Sensor, Temperature Measurement, Battery Indicator
* Notes: For the Inactivity Timeout to update or Battery level (only for the first time),
* you have to open the Motion Sensor and leave it open for a few seconds and then close it.
* This triggers the forced Wake up so that the settings can take effect immediately.
* Author: FlorianZ,Kranasian, Humac, Moonshine
* Date: 2015-09-25
preferences {
input "inactivityTimeout", "number", title: "Inactivity Timeout", description: "Number of minutes after movement is gone before its reported inactive by the sensor."
input description: "This feature allows you to correct any temperature variations by selecting an offset. Ex: If your sensor consistently reports a temp that's 5 degrees too warm, you'd enter \"-5\". If 3 degrees too cold, enter \"+3\".", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempOffset", "number", title: "Temperature Offset", description: "Adjust temperature by this many degrees", range: "*..*", displayDuringSetup: false
input description: "This feature allows you to change the temperature Unit. If left blank or anything else is typed the default is F.", displayDuringSetup: false, type: "paragraph", element: "paragraph"
input "tempUnit", "string", title: "Celsius or Fahrenheit", description: "Temperature Unit (Type C or F)", displayDuringSetup: false
metadata {
definition (name: "Monoprice Motion Sensor", author: "florianz") {
capability "Battery"
capability "Motion Sensor"
capability "Temperature Measurement"
capability "Sensor"
fingerprint deviceId:"0x2001", inClusters:"0x71, 0x85, 0x80, 0x72, 0x30, 0x86, 0x31, 0x70, 0x84"
simulator {
// messages the device returns in response to commands it receives
status "motion (basic)" : "command: 2001, payload: FF"
status "no motion (basic)" : "command: 2001, payload: 00"
status "motion (binary)" : "command: 3003, payload: FF"
status "no motion (binary)" : "command: 3003, payload: 00"
for (int i = 0; i <= 100; i += 20) {
status "temperature ${i}F": new physicalgraph.zwave.Zwave().sensorMultilevelV2.sensorMultilevelReport(
scaledSensorValue: i, precision: 1, sensorType: 1, scale: 1).incomingMessage()
status "battery ${i}%": new physicalgraph.zwave.Zwave().batteryV1.batteryReport(
batteryLevel: i).incomingMessage()
tiles {
standardTile("motion", "device.motion", width: 1, height: 1) {
state("active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0")
state("inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff")
valueTile("temperature", "device.temperature", inactiveLabel: false, width: 2, height: 2) {
state "temperature", label:'${currentValue}°',
backgroundColors:[
// Celsius Color Range
[value: 0, color: "#153591"],
[value: 7, color: "#1e9cbb"],
[value: 15, color: "#90d2a7"],
[value: 23, color: "#44b621"],
[value: 29, color: "#f1d801"],
[value: 33, color: "#d04e00"],
[value: 36, color: "#bc2323"],
// Fahrenheit Color Range
[value: 40, color: "#153591"],
[value: 44, color: "#1e9cbb"],
[value: 59, color: "#90d2a7"],
[value: 74, color: "#44b621"],
[value: 84, color: "#f1d801"],
[value: 92, color: "#d04e00"],
[value: 96, color: "#bc2323"]
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat") {
state "battery", label:'${currentValue}% battery', unit:"%"
main(["motion", "temperature"])
details(["motion", "temperature", "battery"])
def f2c(value) {
// Given a value in degrees Fahrenheit, return degrees Centigrade
(value - 32) * 5/9 as float
log.trace "Parse Raw: ${description}"
def result = []
// Using reference in: http://www.pepper1.net/zwavedb/device/197
def cmd = zwave.parse(description, [0x20: 1, 0x80: 1, 0x31: 2, 0x84: 2, 0x71: 1, 0x30: 1])
if (cmd) {
if (cmd instanceof physicalgraph.zwave.commands.wakeupv2.WakeUpNotification) {
result.addAll(sendSettingsUpdate(cmd))
result << createEvent(zwaveEvent(cmd))
if (cmd.CMD == "8407") {
result << new physicalgraph.device.HubAction(zwave.wakeUpV1.wakeUpNoMoreInformation().format())
log.debug "Parse returned ${result}"
return result
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
//log.trace "Woke Up!"
def map = [:]
map.value = ""
map.descriptionText = "${device.displayName} woke up."
return map
def sendSettingsUpdate(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd) {
def inactivityTimeout = (settings.inactivityTimeout == null ?
1 : Integer.parseInt(settings.inactivityTimeout))
def inactivityTimeoutStr = Integer.toString(inactivityTimeout)
def actions = []
def lastBatteryUpdate = state.lastBatteryUpdate == null ? 0 : state.lastBatteryUpdate
if ((new Date().time - lastBatteryUpdate) > 1000 * 60 * 60 * 24) {
actions.addAll([
response(zwave.batteryV1.batteryGet().format()),
[ descriptionText: "Requested battery update from ${device.displayName}.", value: "" ],
response("delay 600"),
actions.addAll([
response(zwave.configurationV1.configurationSet(
configurationValue: [inactivityTimeout], defaultValue: False, parameterNumber: 1, size: 1).format()),
[ descriptionText: "${device.displayName} was sent inactivity timeout of ${inactivityTimeoutStr}.", value: "" ]
actions
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
def map = [:]
map.name = "motion"
map.value = cmd.value ? "active" : "inactive"
map.handlerName = map.value
map.descriptionText = cmd.value ? "${device.displayName} detected motion" : "${device.displayName} motion has stopped."
return map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv2.SensorMultilevelReport cmd) {
def map = [:]
if (cmd.sensorType == 1) {
def cmdScale = cmd.scale == 1 ? "F" : "C"
def preValue = convertTemperatureIfNeeded(cmd.scaledSensorValue, cmdScale, cmd.precision)
def value = preValue as float
map.unit = tempUnit
map.name = "temperature"
switch(tempUnit) {
case ["C","c"]:
if (tempOffset) {
def offset = tempOffset as float
map.value = f2c(value) + offset as float
else {
map.value = f2c(value) as float
map.value = map.value.round()
map.descriptionText = "${device.displayName} temperature is ${map.value} °${map.unit}."
break
case ["F","f"]:
if (tempOffset) {
map.value = value + offset as float
else {
map.value = value as float
break
default:
if (tempOffset) {
else {
break
map
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
state.lastBatteryUpdate = new Date().time
def map = [ name: "battery", unit: "%" ]
if (cmd.batteryLevel == 0xFF || cmd.batteryLevel == 0 ) {
map.value = 1
map.descriptionText = "${device.displayName} battery is almost dead!"
} else if (cmd.batteryLevel < 15 ) {
map.value = cmd.batteryLevel
map.descriptionText = "${device.displayName} battery is low!"
} else {
map
// Catch-all handler. The sensor does return some alarm values, which
// could be useful if handled correctly (tamper alarm, etc.)
[descriptionText: "Unhandled: ${device.displayName}: ${cmd}", displayed: false]
